Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Top has rattle in spin
Set something on lid while in spin and rattle stops. How does one get top off of machine
  • 61 Answers
There are 2 screws 1 at each side at the rear of the control panel. these screws are going through the end caps at the back. remove the screws and the control panel folds back. there are 2 brass clips holding the top and sides to the frame. remove the clips and the top and sides will just pull away from the frame.
Posted on Dec 19, 2008
Lid lock not on, and machine is not going through
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 70 series Washer will not drain and spin
You have a bad lid switch . Try inserting something into the hole on the top and see if that starts the machine in drain/spin . If not , still bad lid switch . If so , tells you still bad lid switch .
Jul 26, 2009 | Washing Machines
Washer starts to spin and quits after 10 seconds. It is like the spin timer is set to short or something.
place a screwdriver into the lid switch hole when the lid is up, timer on spin be careful as the tub will probably start to spin
if it does check lid switch and, lid for a broken lid pin that goes in the lid switch hole
Jun 08, 2009 | GE WBSR3140DW Top Load Washer
Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
May 05, 2009 | Roper RAS8445KQ Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
