Question about Baby Trend Expedition LE Jogger
Stroller pulls to the right.
I have the Baby Trend Expedition LE and it just started pulling to the right. I know that this is a common problem and it was in my manual for the stroller which I've lost in a move. How can I fix this?
  • 17 Answers
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Posted on Dec 18, 2007
SOURCE:
Where do I get the bearings for the front wheel. cannot find a bike shop or car parts shop. do not have the right size bearings.
i found them on ebay, just math the numbers listed on the bearings you have.they are the same bearing commonly used on skateboards.
jay
Mar 24, 2011 | Baby Trend Expedition LE Jogger
Manual
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Apr 08, 2010 | Baby Trend Expedition LE Jogger
How to fix a flat baby trend 9292tw back wheel
I found a tab just next to the wheel on the axle that released it so I could remove it.
Oct 19, 2009 | Baby Trend Expedition LE Jogger
Need thebabytrend instruction manual from the URL posted
The manuals for baby trend strollers can be found at www.babytrend.com.
Click the help tab at the top. Go to product instruction manuals and choose the model of stroller you need.
Hope that helps!
Jun 08, 2009 | Baby Trend Expedition LE Jogger
I'm looking for a back wheel,for a Baby Trend Expeditions -Stroller
Contact me. I just parted out a baby trend stroller.
I have all of the wheels and any thing else that bolted to the stroller.
My email address is briazoo4@msn.com
Thank you
Jun 04, 2008 | Baby Trend Expedition LE Jogger
EXPEDITION
Hi I'm looking for jogger stroller seat pls help to find and buy those seat
May 01, 2008 | Baby Trend Expedition LE Jogger
Stroller baby trend expedition guide manual
please send me an instruction manual guide for the baby trends expedition stroller
Dec 26, 2007 | Baby Trend Expedition LE Jogger
Hand Brake not functional
I checked the Baby Trend website and did not see a listing for an Expedition LE Jogger stroller. I did, however, find the Expedition LX as well as several other Expedition joggers with numbers at the end.
Here are instructions to the LX Jogger.
Here are instruction for the Standard Expedition Jogger.
Here are instructions for another version of the Expedition jogger, as well.
You should be able to use one of those to best match your stroller and make sure you have correctly assembled your stroller. Should you need further assistance, they have a customer service line at (800) 328-7363 open from 8:00am to 4:30 pm, pacific coast time.
Dec 14, 2007 | Baby Trend Expedition LE Jogger
Baby Trend Expedition LE Jogger Logo
2,389 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Zarir Irani
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
