Question about Acer Aspire 3100-1405 Notebook
Will not boot windows
Will not boot up windows vista, startup repair will not fix it
  • 827 Answers
Tap F8 on Startup and it'll open up Advanced Settings/BIOS. Tap to Start WIndows in Safe Mode. When you have gotten to the Safe Mode Desktop, navigate to My Computer > C:// > WIndows > System32 and scroll down to an Application called rstrui .
Double-click on that to restore the system back to a point before it was messed up.
Hope that helps
Chris (ziraffa)
Posted on Dec 21, 2008
My laptop is an A215-S4747 and it keeps running startup repair but then says it can't fix it, what do I do
try this...Fix #1: Boot into Safe Mode
  1. Insert the disc and reboot the system.
  2. Press any key to boot from the DVD.
  3. Choose your keyboard layout.
  4. Click Repair your computer at the Install now screen.
  5. Click Troubleshoot.
  6. Click Advanced options.
  7. Click Startup Settings.
  8. Click Restart.
More items...
Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1
https://neosmart.net/wiki/startup-repair-infinite-loop/...or goto this link. https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=laptop%20it%20keeps%20running%20startup%20repair
Dec 11, 2016 | Computers & Internet
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
Boot MGR IS MISSING
What actual operating system do you have?
Windows XP does not use the Boot Manager as this was introduced with Windows Vista or Windows 7 and higher versions.
If you are missing the Boot Mgr for Windows Vista or 7, then you will need to do a Startup Repair which you can do using either a Recovery CD if you have one, or else using the Vista or 7 installation disc.
See the following links:
Windows 7 recovery options
Windows Vista startup repair
Jan 11, 2012 | Microsoft Windows XP Home Edition
I was told it needs reformatted the message on
If you have a windows installation disc, you can boot with it and choose repair. Let windows repair the startup files. In Vista, just boot with the disc, choose repair, vista will search the windows installations and give you the result, you highlight the installation and hit repair.
If you have XP, choose repair and when is says to exit to go to recovery console ot install, click install > click F8 to agree > windows will search for windows installations, again highlight the windows installation and choose to repair at that point, windows will attempt to fix the startup files.
Sep 26, 2009 | Acer Computers & Internet
I can't restart my window vista laptop solve plz
Windows Vista is not starting due to missing or corrupt files.
Run Startup Repair using Vista Operating System disc
  1. Place the Windows Vista Media Backup DVD into to the optical drive and start the computer.
  2. Press any key to boot from CD or DVD.
  3. On the Install Windows screen, click Next.
  4. On the Install Windows screen, select Repair your computer.
  5. In the System Recovery Options dialog box, click Next.
  6. In the System Recovery Options dialog box, select the appropriate operating system, and then click Next.
  7. In the System Recovery Options dialog box, select Startup Repair.
  8. The Startup Repair attempts to locate and resolve issues with the computer.
  9. If prompted, Do you want to restore your computer using system restore?, click Restore.
  10. In the System Recovery Options dialog box, click Finish. This screen can vary, dependant on if a problem was found or not.
  11. System restarts.
  12. If the problem was resolved, the computer restarts into Vista.
  13. If the problem was not fixed, the error may present itself again.
  14. Run Startup Repair again.
  15. If Startup Repair runs more than three (3) times, when available, select View advanced options for system recovery and support.
  16. For further troubleshooting, select one of the following options:
    • System Restore
    • Command Prompt
    • Last resort - Recovery Manager. Recovery Manager is not available if accessing WinRE via Vista OS Backup Media DVD
or you can use any software that can repair and recover your windows files.
Best regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 02, 2009 | Microsoft Windows Vista Ultimate Edition
Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Jan 05, 2009 | Computers & Internet
Boot Manager
You will want to do a Windows Recovery Environment Startup Repair, follow the instructions below to fix this issue:
To access the WinRE using the Vista install disk:
  1. Boot from the Vista install disk
  2. Choose your language settings and click "Next"
  3. On the bottom of the screen click the link "Repair Your Computer"
  4. Select the Vista installation to repair and click "Next" and it will launch WinRE
The following options are available in WinRE:
  • Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
    After attempting to repair the system it will display a Startup Repair diagnosis and repair log with the different Test Performed and the probably root cause.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
Desktop.ini
start your machine...when the sony screen disappears press F8 (to get safe mode options) one of these options is a vista startup repair....choose that one.....takes a couple of minutes to fix and boot into windows so be patient....the reason you have this problem is the user profile has become corrupt but windows vista corrects this with startup repair
Aug 06, 2008 | Microsoft Sony VAIO 3544501 Notebook
Acer Aspire 3100-1405 Notebook Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
