Question about Hitachi Travelstar 80GN 60 GB Hard Drive
What is the jumper setting to make this a slave
The drive doesn't show slave setting. This drive has a boot virus and can't repair with windows XP disk. When I scan drive the scan gets to 39% and then ends (Bad Sectors). Tried to put this HD in enclosure and my desktop doesn't see drive that is connected thru the USB port.
    Novelist:
  • 86 Answers
How do you know that the HDD has a boot-sector virus? Can you tell us which specific boot-sector virus you're trying to remove? This is the direct link to the .PDF file with the jumper setting information you need: http://www.hitachigst.com/tech/techlib.nsf/techdocs/78090BF330EAFDA687256C4E0077DA0A/$file/T80gn_ig.pdf As you'll see, you need to move the jumper to the A2 position in order to set the drive as Slave, BUT, keep in mind that in order to use the drive through a USB enclosure, you will probably have to set the drive as Master, not Slave. Changing the jumper to the Slave position will DISABLE the onboard IDE controller, which could prevent the system from finding the drive through the USB port (which is what you've already described)... Which program are you scanning the drive with? Are you using an anti-virus program, ScanDisk, or something else? Please provide more details; removing a boot-sector virus can be difficult, so the more information you provide, the better the chance that we can help you resolve this...
Posted on Mar 30, 2007
  • Printer Hater Mar 31, 2007
    Since the original URL I posted has been mangled, I'm posting this TinyURL:
    http://tinyurl.com/3bonng
    If you're worried about opening that link without being able to see exactly where it leads, you can use the Preview link:
    http://preview.tinyurl.com/3bonng
    Post here again if you still need help.
  • 64 Answers
If it's USB you shouldn't have to mess with the jumper settings but here is a site that appears to have them for TravelStar: http://www.ontrack.com/jumperviewer/ If the drive is not showing up in My Computer make sure there is a drive letter available for it to use. You can right click on the My Computer icon, select Manage and then go to Disk Management and see if the drive shows up there and then assign it to a different letter.
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
I have used my maxtor 8 as a slave. I now wish to use it as a normal drive. My attempts to install XP produces an indication that NTLDR is not present. I have managed to start the installation program but...
If you had it set to slave status, there is a jumper on the drive controller next to where the cable plugs into. that jumper needs to be set to the correct position. typically there are 3 jumper positions Master, Slave, and Cable Select. If this is the only drive in the system, you can set it to master or cable select position. If there are multiple drives, then every drive needs to be set to cable select.
The diagram on the drive label should tell you which jumper is cable select position.
Oct 04, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
I want to reinstall my window xp operating system i set the dvd rom as the first boot but it says not found
turn off your pc, open it, and check cables and connectors, check the jumper settings on your DVD drive. if you want, you can isolate the problem by simply connecting only the DVD, disconnect the Hard Drive and test.
Jul 07, 2009 | Microsoft Windows XP Professional
Win98 hds in win xp dont show other program says not formatted
you will need to revert back to the master/slave setting.  As slave/slave neither disk will be the main controller. Try reverse the master disk to the slave, and the slave to master, as it may be that the controller has a fault which is why you were having the original win98 problem.  Let me know how you get on
Jun 20, 2009 | Computers & Internet
Hard drives show up in BIOS but not in My computer? WHATS UP?
You should not use line select on any of the drives at this point. Set the jumpers on the components to one master and one slave on each channel. Personally I would put one HD and one optical drive on each channel and make the optical drives the slaves but that's not required. Win98 uses a different file system than XP (FAT32 compared to the newer NTFS) but you can still use the drive. I would copy all the files you want to save and then reformat it using NTFS for better performance.
Boot into XP, both HD should show up when the jumpers are set correctly. If they still do not show up go into your BIOS and double check that all master/slave designations match what you have set the jumpers to.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Hard drive problem
Although I covered most of the ways to speed up Windows boot time in another article, I encountered a unique roadblock recently that made me write this article.
During the last week I was asked by a customer to upgrade one of their office computers from Windows 98SE to Windows XP. Normally this is pretty standard, however because their current hard drive was only a 20GB with a gig or so remaining I wanted to upgrade their hard drive as well.
I proceeded to ghost the drive to a larger hard drive and then installed an upgrade version of Windows XP on top of Windows 98 to preserve all of their settings and programs.
Everything went flawlessly, until I was finished...
After I completed the Windows XP upgrade, I shut down the computer completely and restarted it. The computer took FOREVER to boot into Windows XP. It was literally 2 minutes before I saw the Windows XP logo screen and another 30 seconds more before the desktop appeared. This was definitely a problem.
After checking multiple settings in the BIOS, I compared the old and new hard drives. Everything seemed to be normal, except one. The old hard drive was setup to Cable Select and as my normal routine I had set the new hard drive as a Master drive. I changed the new hard drive to Cable Select, rebooted the computer, and the Windows logo screen came on seconds after the POST screen as before. Therefore, I have to add one more item to my list of ways to make Windows boot faster. Try changing the hard drive from Master to Cable Select, check the boot up speed and switch back to Master if you don't see a change.
Master/Slave Settings
Now for a refresher course on hard drive connections. When connecting more than one hard drive to a computer on the same IDE controller, you generally have to assign one as the primary (master) and one as the secondary (slave). You do this by changing the jumpers on the hard drive next to the power connector. Normally, the drive will have a diagram to let you know which jumper should be set for a master drive and which to set for a slave drive. You'll notice in the picture below the jumpers are circled on the end of the drive and the top of the drive shows the diagram to follow.
After changing the jumpers, connect the hard drive cable from the motherboard to the hard drives. Under normal circumstances, the end of the drive cable attaches to the Master hard drive, while the inside connector on the cable connects to the Slave drive.
What About Cable Select?
Cable Select (CS) settings were designed to make it easier to connect hard drives because you didn't need to bother with setting the Master/Slave jumpers. You just connect the drives and depending on where you connected them to the cable the computer would know which is Master and which is Slave...in theory. Now comes the confusing part.
With cable select, you first needed a special 40 conductor IDE cable that would determine master/slave connections. This was different from the normal IDE cables at the time. Also, the Master connector on CS cables was the inside connector not the end connector. This made for a very confusing switch from everyday master/slave configurations.
80 conductor Ultra DMA cables WILL determine the Master/Slave settings through Cable Select however. So as technology advances, Cable Select as a concept may still catch on. With the newer Ultra DMA cables, you can set both drives to Cable Select (CS), connect them and they will work. Another change with the 80 conductor cables, the Master connector is on the end of the cable where it should be. In situations where you are using a newer Ultra DMA drive and cable, you can use Cable Select or standard Master/Slave jumper settings and the drive will boot properly.
In my scenario to start this article, the change from Master/Slave to Cable Select for this particular computer reduced the Windows boot time by more than 2 minutes.
For more information on Master/Slave settings versus Cable Select visit the following pages:
Mike's Hardware: How to Connect IDE Hard Drives
Configuration using Cable Select
UnixWiz.Net: Using IDE Cable Select
Oct 18, 2008 | Computers & Internet
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
Please help
make sure that when you fitted the drive that the plastic jumper cap on the back of the writer was set to master if used on it's own IDE cable, or set as slave if it is sharing and IDE cable with another drive, you will find the master and slave positions either underneath the unit or above the jumpers at the back.
Jul 11, 2007 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Hitachi Travelstar 80GN 60 GB Hard Drive Logo
789 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Fotis Papastamatiou
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
