Question about Vacuums
Hello.ps.donow the nearest electrolux repair shop in lawrenceville Ga.ofori
  • 107 Answers
You can take it to any Best Buy to send in for service.
Posted on Dec 19, 2008
Where do I get Electrolux motor in south Africa?
A local rewind or motor repair might prove more convenient and perhaps cheaper but Electrolux service is available in South Africa
Electrolux South Africa ' Home Appliances and Household Appliances
www.electrolux.co.za/
Welcome to Electrolux South Africa. Discover our range of ... Enter your postcode, town or city to find your nearest authorised dealer. Translation missing for ...
May 03, 2016 | Electrolux Vacuums
Electolux hoover 1600w power plus wont start
John, first off, you have a Hoover upright vac, not an Electrolux. If it won't start, check cord to be sure it's plugged in properly to a live socket, then find and push reset button, frequently found near the corner on the rear of the base. (Small red circle). If that fails,. then you need to take it to the nearest repair shop for diagnosis.
Nov 02, 2013 | Hoover Platinum Collection Upright Vacuum
Electrolux regency series upright vacuum cleaner 1572e belt replacement
Hello see the video below for help otherwise for about 20 bucks take it to as local shop Changing belt on an Electrolux upright vacuum
Nov 26, 2011 | Electrolux Vacuums
Need to open the canister to get to the cord assembly of my Electrolux Lux 5000
Why do you need to get to the cord assembly?
If the cord will not retract, tilt the vacuum to about a 45 degree angle and gently tug and release cord. It will usually retract.
Due to problems ensuing from untrained persons attempting to reassemble the vacuum and having to take it to the shop anyway, I recommend not taking it apart.
If the above isn't the problem, please take it to the nearest Aerus Electrolux store for repair.
http://www.aerushome.com/storelocator/
Jan 22, 2011 | Electrolux Lux 5500 Canister Vacuum
CORD SPOOL WILL NOT PULL BACK
Try tilting the vacuum to about a 45 degree angle. Gently tug and release the cord a few times. This usually will release the cord. If not, the cord winder may have broken, or the spring came loose, and it needs replaced/repaired. Take it to the nearest Aerus Electrolux store for help/repair.
Jan 19, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do i open the housing of an electrolux ambassador model #c101j to fix cord recoil
This can be a complex undertaking, so I highly recommend taking it to the nearest Aerus Electrolux store for repair. I've seen many disassembled machines come in to the shop because the owner couldn't figure out how to put it back together. Any misplaced wires during reassembly can result in nonworking vacuum, shock and even fire hazard.
Taking it to the shop may cost more, but I believe is less expensive in the long run. They'll do it right.
Dec 14, 2010 | Electrolux Lux 5500 Canister Vacuum
I replaced the bag full, but the bag full light stays on.
This is most likely due to a broken, worn, or clogged control valve assembly (CVA). You can try resetting the dial to the smallest dot, but I'm not sure that will work for you.
Detach hose from vacuum. Turn vacuum on. If it runs, place palm over intake port. If it shuts off, then it's the CVA. This is a shop repair and should only be done by an authorized Aerus Electrolux service tech. It may seem spendy, but they can also do a clean and service to remove any dust in the interior of the machine and motor. This will extend the life of your machine if there's much dust in it.
The cause of this problem is often due to using "made to fit" Electrolux bags rather than the genuine bags. Genuine bags will always have "Home Solutions" printed on top.
For the nearest Aerus Electrolux store see below site.
Dec 12, 2010 | Electrolux Epic 6500 Vacuum
The agitator brush of my central vacuum cleaner didn't roll.What's the problem of it?
If the power nozzle motor is running, then the problem is a broken belt. It's recommended that it be taken to an authorized shop for replacement.
If the PN motor is not running, locate the reset switch on top of the PN and depress. If the motor still does not come on, there's a problem in the wiring or power module. The entire machine, including hose, wands, and power nozzle needs to be taken to the nearest authorized shop for exact diagnosis and repair/replacement of parts.
If the machine is the old style Electrolux (now known as Aerus), not sold in home improvement stores, the nearest authorized store can be found on the below site. Just follow the instructions.
Dec 07, 2010 | Electrolux Central Vacuum
I have to go into the garage to turn on the motor on the tank and to shut it off. When I plug the hoses into the outlets in the house, it doesn't turn on the tank motor. I don't know what part to get and...
Is this Electrolux that's now known as Aerus? If so, take it in to the Aerus Electrolux store for a tech to look at. You can find the nearest Aerus Electrolux store by following the instructions on the site at bottom of page.
It sounds like a problem with the power module in the vacuum. Without checking for myself, that's my best guess.
Nov 21, 2010 | Electrolux Central Vacuum
I have an Electrolux Epic 6500 SR vacuum and the hose end with the handle is separating. Power nozzle losing contact intermittently. Is this piece replaceable or repairable?
It is replaceable. Just take it to the nearest Aerus Electrolux store and the service tech will take care of it for you.
Go to the following site and follow instructions to find the stores nearest you.
Nov 18, 2010 | Electrolux Epic 6500 Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
