Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 will not power up
Power light comes on and goes off 3 or 4 times and dies.
  • Rod Bullard Dec 20, 2008
    I downloaded a 'service manual' from servicemanuals.net but it wasn't in Adobe PDF format as advertised. When I unzipped the file, it contained several schematics but they are AutoCad '.dwg' files, which are huge and VERY difficult to view in anything but Autocad ($1,000 +)! Additionally, these schematics do not identify the specific boards they represent or where any specific board is located. There's no index or table of contents either.
    I'm aware of the flyback, high voltage splitter & capacitor problems (cp111, cp114, cp120 & cp150) that can cause this problem, but can positively identify only the flyback xfmr. Where can I get a component locator for this infernal tv?
  • 916 Answers
Check here
http://www.fixya.com/support/t1371727-problems_powering_up
Posted on Dec 20, 2008
    Scholar:
  • 113 Answers
Is it under warranty? if it is, you need to bring it back where you purchase it. you have bad power supply, thats due to its components that were weakened that needs replacement.  if the warranty is already over and if you know a bit on electronics then try this, be sure to unplug the power to avoid electric shock, then it needs to be short circuited so that no static electricity that would shock you. okay, focus on the supply, the problem is at the component like capacitors, transistors, and diodes or the problem is in the power switch itself, then test them all with your electronic digital tester, from the power supply, power switch to the next board trace them all, I'm sure  the you will find the problem on that portion.  if in case you don't have any idea, feel free to ask help at any electronic service center near you. Have a good day!
Posted on Dec 19, 2008
  • 2,323 Answers
Check the link below for more info on where the failure could be:
http://www.fixya.com/support/t1376444-will_not_come
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
Tv green light flashes on and off 3 times. Never comes on.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
check the components as given above and if necessary replace the components to solve the issue.
This will help. Thanks .please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W19 when tv turn on the power light blink 3 times but nothing hapen
Cp150, CP120 and CP114 repair kit form www.tvrepairworld.com should solve that issue. The kit comes with the instructions on CD.
Nov 19, 2009 | RCA D52W19 52" Rear Projection Television
TV will not power on. Button slowly flashes green several times
CP120, CP114 and CP150 need replacement. You can get replacements at the following link under the RCA parts catagory.
http://servicemanuals.vstore.ca/
Aug 22, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52 in. Rear projection hdtv problems
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
Rca hidef tv
Most likely a bad power supply module. The 3 tries is the 3 strike rule with the RCA TV's.
May 26, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
19 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
