Question about Frigidaire PLEF398AC Electric Kitchen Range
My oven won't come up to full temp - but broiler/clock work fine.
No matter how high we put the temp on our Model #PLEB30S8C Frigidaire Professional Series Electronic Wall Oven it will only get to 225 degrees. The Broiler and clock work fine...I've looked the model up and can't find anything. The oven is only a few years old - and I really don't want to purchase a new oven yet. I NEED my oven...it's not quite BBQ weather out right now and I'm really missing out on the baking season! I would like to try to fix it myself - rather than call a tech...and all the relatives want to come to my house this year. HELP!
  • sharolette Jan 02, 2009
    My friend wouldn't take the advise and insisted it was the heating element so we bought a new one - but it still didn't work. So we had to go back and order a new OEC, which due to timing had to be overnighted. They gave us a store credit for the heating element which we applied towards the OEC and the overnight shipping charges. I wish I would have had the electric meter it would have saved a lot of time. Thanks for the info...It's great to have my oven back!
  • sheino673 Apr 19, 2009
    same issue. what is an OEC?
    Sergeant:
    Champion:
  • 338 Answers
You either need a temperature probe or a board if the element is heating. If you have an electric meter ohm out the temperature probe. it should be a long skinny piece of metal coming out of the top left or top right corner of the oven cavity. if you ohm it it should read about 1250 ohms.. on your meter that would be the horseshoe looking thing. if it ohms out correctly then it may be your board.
Posted on Dec 19, 2008
My frigidaire professional gas oven doesn't heat to set temp. Burners and broiler work fine. Model is FPG53085kfa Any suggestions?
Hi friend, thank you for your post!
I understand that the oven will not hold temperature properly inside your Frigidaire range. I would perform a reset which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 17, 2014 | Frigidaire Kitchen Ranges
Where are the relays that controls the oven on frigidaire electric range located
if range is self clean make sure door is closed, put on self clean wait about 0ne minute or so then cancel self clean . sounds like range is stuck in door lock Cheers
Dec 11, 2013 | Frigidaire FEF366 Electric Kitchen Range
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
Sep 20, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire PLEF398AC Electric Kitchen Range Logo
241 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
