Question about Coleman Powermate Powermate 5000W Generator
Generator Wattage I was wondering if anyone knows if a 2000 or 2500 watt generator would be a good fit for running a computer, monitor, cable modem and firewall. I guess i don't want to have the generator go into a brownout condition if i have too much equipment for it. Thanks...
Be very careful with anything electronic. These generatore are not regulated electronicaly, only by the RPM. I would invest in a voltage regulator for voltage spikes and high voltage but you will still have to watch for "brown outs" (low voltage) which will burn out electronics as well.
Posted on Dec 31, 2008
    Problem Solver:
  • 10 Answers
Both sizes will handle that stuff as long as generator maintains a constant rpm. otherwise you run risk of low voltage or voltage spikes which cpu will not handle for very long
Posted on Dec 19, 2008
What faults can a change over switch caurse between the generator and the load
One consideration is how many circuits and how much total wattage is being used when the generator is in service.
"Gas Powered Generator GG2300 2300 Watts Surge 2000 Watts Continuous Output 10 Hours of Run Time at Full ."
This is a relatively small generator with 2000 watts output, so the problem may be that the generator can not handle the wattage demand. You can get a pretty good estimate of the wattage demand by adding up the wattage of everything , all lights, appliances, etc that's being powered by the generator. If the total wattage is greater than the output of the generator (2000 watts) then the generator is too small.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
My 3000 watt Duracell inverter will not start a 1 1/2 hp electric motor. The voltage drops to 45v and the electric motor struggles to reach full rpm. This is a table saw with no load. The generator revs...
have the saw motor checked for internal and wiring problems
check the start/run capacitor of the electric motor
running a 1 1/2 hp motor (1075 watts) on a generator that has a running wattage of around 2250 watts means that it should start and come to speed immediately if the motor is good
the problem indicates that there is a circuit problem in the saw motor that is exceeding the available wattage (3000 watts ) on start up
Oct 22, 2017 | Duracell DS30R1i 3000 Watt Continuous...
AC surge current?
you are missing the voltage supply here to get an definitive answer
for 240 volts drawing 4.8 amps the required wattage is 1152
for 120 volts the wattage is 576 watts
for 120 volts with a current of 900 watts , it equates to 7.5 amps
with 240 volts with a current of 1150 watts , it equates to 4.79 amps
so you can see the problem by not stating the supply voltage
get access to an cable clamp amp meter / watt meter from an electrician and read the current on starting the ac unit
if it exceeds 900 watts for 120 volts or 1150 for 240 volts , consider a bigger generator
Aug 31, 2017 | Fixya.com Heating & Cooling
I have a kenmore refrig/freezer. Full load amp is 6.5 , 60 hz and 115 volts. I have a generator that will take 1100 watts with 1500 peak or surge watts. I heard that refrigerators use more electricity or...
The calulation of max wattage is going to be 750 watts at start up and be around 500 on normal running wattage after start up so a 1100 watt generator should be fine.
GENE
Sep 06, 2011 | Kenmore Refrigerators
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
Can a 220volt floor sander be run off a generator
Hi Glen,
Welcome to fixya!
You would have to check the capacity of your generator. If it can handle 220 volts and the amp rating of the floor sander does not exceed the amp rating of the generator, you should be good to go.
Good luck.
When you accept this solution, please place a vote for me.
Thanks,
Handie Andie
Aug 19, 2011 | Garden
I am interested in a generator that can light a 3-bedroom hse and a chauff cutter
Your cutter machine may use more power than your whole house depending on the size of motor. A one horsepower motor 115v will use about 3000 watts to start and about 1000watts to run. To estimate how much power you need, add up all the watts that you will use at home and add to that estimated wattage of the cutter motor (motor will use 3x rated wattage to start plus loss of power thru the extension cord). Buy a generator that will give you needed power and still have a 25 percent reserve. If you need 2000 watts on a continued basis, the 2800 watt may be good, however I would be more comfortable with a 3500 watt if the price was right because of the cutter machine. I would consider converting the cutter to gas power and buy a smaller generator to save on gas since you will be most likely running the generator far longer to power the house. Good luck
Aug 11, 2011 | Yamaha 2500 Watt Industrial Inverter...
We have a Valsi 5500 watt generator that isn't putting enough voltage out to run everything in out small travel trailer. It runs the lights but doesnt push out enough voltage to carry the A/C, microwave,...
How long have you had this generator?
Has the generator worked on all of these loads before?
Model 5500 is a 5500 Watt generator which could easily be 5500 watts (Peak) and not continuous.
Your AC is an inductive load.
Your lights are resistive loads
An inductive load can cause issues when starting due to an increased current demand at start up that some generators cringe under. Do the lights flicker or are they stable? I'd say your diodes on your stator are working if you have light stability but you haven't provided nearly enough information for a detailed solution.
I'm sure you have enough voltage but you aren't getting enough current to run specific loads. How many watts is your AC? How many watts for your microwave? Both of these units demand a great deal of energy to run and when you place too much demand on your generator, it will choke it out and eventually, will cause damage to the generator. You may consider getting a beefier generator with a greater amount of wattage output.
Seeing these specs online and noting what you are trying to run, you have an undersized generator and need to get one that can produce a greater amount of running wattage (as well as peak wattage).
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
Kenmore top mount refrigerator, 18 cubic feet. how many amps doe it use. question is for purchase of emergency generator. spec Plate states 4.5 amps, is that accurate? Refrig is 115 volts, 60 hz
Good day,
That sounds about right, however if your generator is rated in wattage the amps times volts won't work.
On an induction unit, such as a refrigerator, the wattage is volts times power factor times amps.
Nominal wattage should be around 375 watts. However, during auto defrost the heater will probably be around 450 watts.
As well, locked rotor amps on starting will be about 4 times running amps approx. 18 to 20 amps. so your generator will have to be able to handle that.
The short and long of it is give yourself wiggle room.
Aug 24, 2010 | Kenmore Refrigerators
Honda generator runs great,voltage output is good but when load is applied motor cuts off. no breakers tripped or resets tripped?
check your load..the generator is carrying heavy weight when you are going to load a high wattage thats why its RPM will turn slowly and have the possiblity to stop it...It MUST be needed the the given wattage of the generator is greater than the load you apply.for example:when your generator's specification is 3500 watts,tehn the load you are going to apply is i watts to 3499 watts only..
Nov 03, 2009 | Computers & Internet
Coleman Powermate Powermate 5000W Generator Logo
380 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
