Russound Home Theater w/IR
Just replaced power supply, double checked the watt/v, plugged it into wall panel and a pulsing heart beat-like sound comes through the speakers--the red light power indicator light pulses on and off as well on both the wall panel(inside of it only visible since I removed it from wall) and the wall control IR panel.
Please advise.......The shop guys say it's the panel, but that costs $174.00!!!!
Thanks for your time and assistance.
Doyle Haverfield
  • GunnerCDM May 02, 2009
    I have the exact same problem except the red light doesn't blink, the red light just never turns on. Same heartbeat like sound coming from the speakers.
  • 4,234 Answers
Sorry about the late response, I didn't get a notification of this posting...
Can you update this with the make and model of the unit please. It sounds like this is a continuation of another posting, but I can not find the original.
Thanks,
Dan
Posted on Dec 23, 2008
What is a normal pulse rate?
A normal resting heart rate for adults ranges from 60 to 100 beats a minute. Generally, a lower heart rate at rest implies more efficient heart function and better cardiovascular fitness. For example, a well-trained athlete might have a normal resting heart rate closer to 40 beats a minute.
Apr 23, 2017 | Cars & Trucks
Power wont turn on on my motorola DCP-501
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 10, 2016 | Motorola Mobility Dcp 501 Home Theater...
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
I have a Panasonic SA-HT650 Home Theater system that has stopped working. The panel code is F61
A power source problem. Means there is voltage measured at the output/speaker cable connections. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the power ac power source from the wall is wired correctly and has proper voltage and grounding.
Apr 07, 2010 | Panasonic Home Theater System System
Prima HT-TW57P (Home theater wont turn on)
Hiya, Sorry to say it does sound a little like there is power supply damage. They are generally not to difficult to sort out but will require someone with electronics experience IE friend, shop in the area etc. Shouldn't be to much provided it is only power supply
Jul 10, 2009 | Audio Players & Recorders
I have a JVC TH-M505 home theater system and when I plug everything together and turn the power on the main unit and begin to play a cd/dvd etc...I cannot get the sub unit to power up (the light does not...
you may want to re check all your connections.
are you plgged into a power bar or directly into a wall socket.
also you may have a defective power supply on the system . you can also check this website out it is free to join and you can download manuals and get help
http://audio.manualsonline.com/manuals/mfg/jvc/jvc_th_thm505.html
Apr 26, 2009 | JVC TH-M505 System
Does the Comcast remote work in IR and UHF? Infrared and UHF(able to go thru walls or floors.
Depends on the converter box but chances are yes its has both communications.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | RCA HD52W59 HDTV Projection Television
Big screen no picture and makes heart beat noise?
can be a faulty mains board, does the sound still work? if not, can be mains board, and at last if there is a continuous clicking sound it a faulty power supply.
hope that help
pls rate me!
Mar 21, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
GETTINF OVER HEAT
Onkyos are notorious for running a bit warm - though if yours is excessively warm, double-check the impedance of, and wiring -to- your drivers.
Nov 13, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
96 people viewed this question
 Grubhead
Grubhead
