Question about Dell Dimension 8400 PC Desktop
Error in system check 0f00:136c (resource cd, installation cd)
8400 dell.  ran antivirus scan.  blue screen came up.  rebooted and got error.  running system tree now
  • 1 more comment
  • radonna Dec 19, 2008
    i had a SAT?? error on diagnostic check.  last time i tried i could not get system restore to work.   computer is very slow.....i almost want to reset to original settings.  i have been doing this for days.  i have everything stores but i am not sure what to do
    i cannot run a check on c drive or do a cleanup etc
  • Anonymous Mar 10, 2009
    systemrestore works to the last step then will not take
    President:
  • 623 Answers
During the diagnostic process (especially if you're using the 32bit diagnostic) it is ok to receive the error Code 0F00:136C.
This test detects all the external peripherals. An optical drive which doesn't contain a disc can return this error. Disabling certain applications during start up can help you to eliminate the problem. If possible, run the custom test under diagnostic which will provide a summary of the issues of your computer.
But, as Smithbrother suggested, a System restore is always a good option, unless your hard drive's MBR has failed.
Posted on Dec 19, 2008
    President:
  • 2,692 Answers
Use MS Systemrestore to restore it to an earlier time or do a complete PC backup. See Dell website below:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=5E3CADE8347C1C3CE040AE0AB5E1
Dell N5010 Windows 7 64 bit stopped running I had to reorder my recover & restore usb (not available in cd anymore) ok ran this it came back no errors but no hard disk detected but then I checked the...
Tap f8 key on your keyboard while your system reboots and before that windows logo appears on the screen. Go to option safe mode or safe mode with networking using arrow key. You can run the antivirus to scan your system and create a restore point and take the backup on the external drive.
After that if you wanted to format your system you can format it with the Win & OS CD.
You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
May 16, 2013 | Computers & Internet
Hi there, Our Dell Inspiron 1525 specs are as follow: Windows Vista Home Basic Service Pack 1 Intel Core 2 Duo T5750 @2GHz 2GB RAM - 32-bit OS Symptoms are: - Freezes oftenly after random period...
Do you have any CD's thatcame with your laptop? If so, look for one that has "Diagnostics and utilities"listed under the "Contents". You will have to boot from that CD disk. To dothis, power on your laptop and tap the key to bring you to the "Onetime boot menu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the32 Bit Dell Diagnostics". Next select the "Express Test" and see if any errorsare detected. If no errors are reported, then your operating system software isprobably the culprit.The blue screen of death can be caused by hardware or software. If Diags pass you probably have a software issue. If you don't have the resource CD press the key while powering the system on. This will run theDell built-in Diagnostics.
Feb 22, 2011 | Dell Inspiron 1525 Notebook
STOP: 0x000000c2 message appears on my dell
you need to reboot you system.
1 just back up data
2 re-install operating system.
Jun 07, 2010 | Dell Dimension 8400 PC Desktop
Dimension 8400 locks up. Keyboard won't respond.
Generally and indication of a software issue that is locking the system. There can be hardware causes too.
  1. Run diags on the system (From Resource CD or F12 menu) see if any failure. If you have a hardware failure then address it and see if the problem is solved.
  2. Update bios and drivers from support.dell.com
  3. Edit MSCONFIG, startup group, remove entries that are not required (Generally only AV and printer scanner items are needed here, most other items will function without and item here)
  4. Edit the Virtual Memory settings, and set it to Custom and an amount double the RAM (EG: 4 GB RAM set initial and Mas to 8200 MB VRAM)
Apr 04, 2010 | Dell Dimension 8400 PC Desktop
Computer keeps freezing up just a new computer ran a scan nothing wrong
This happened to me once because my system ran out of resources. I closed everything that is running in the taskbar and applications that are not important like widgets and items that are not important in the device manager then ran again the antivirus. This also happened in another machine that we almost do not shutdown. A reboot and ran the antivirus and it worked.
Jun 03, 2009 | Microsoft Windows Vista Ultimate Edition
Dell blue screen tests got data bus system
I presume you ran the 32bit Dell diagnostics. The memory test failure indicates that the memory module has failed. If you have more than one memory installed, you can try removing one at a time and run only the memory test (from Custom test option), this way you can isolate the faulty memory. If you have a warranty for the computer, Dell would replace the memory for you (Check warranty status from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen )
As for your other problem “it just does nothing when i type r for recovery”, you would need to go to the bios, under the “Drives” tree, under “SATA operation” you would need to change option one to two and save and exit. This is applicable on for the Dim 8400. But you would not need to do this if the prvious steps resolve you issue
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell Dimension 8400 PC Desktop
Bad_pool_header
Microsoft doesn't seem to have any information on XP having this error. But here's the general consensus after a little investigation:
1. Boot into safe mode by pressing the F8 key repetitively right after you turn on your PC until you see the safe mode screen.
2. Click Start >> Run. A Run window will appear.
3. Type "services.msc" in the Open field and then click OK. A "Services" window will open.
4. Find "Indexing Service" and double click on it. A "Indexing Service Properties" window will open.
5. Find the "Startup type" dropdown menu and select "Disabled", click "OK", and close the "Services" window.
6. Double click "My Computer" on your desktop. If it isn't there, then go to Start >> My Computer.
7. Find your hard drive, usually labeled "Local Disk (C:)", right-click on it and select "Properties". A dialog box will open.
8. Select the "Tools" tab.
9. In the upper third of the dialog box you'll see an area zoned "Error-checking". Click the button "Check Now". A new dialog box will open.
10. Check off the boxes "Automatically fix file system errors" and "Scan for and attempt recovery of bad sectors", then click "Start". You may be prompted to restart the computer. If this is the case, go ahead and restart.
Windows will check the hard drive for errors and run a surface scan. This may take a while depending on how big your hard drive is. Once it is finished, you'll arrive at your normal login screen. If Windows went ahead and ran the scan in safe mode without requiring a reboot then, once it is finished, go ahead and reboot the computer. Once at the login screen, go ahead and login. You shouldn't have the error any longer. If you do, be sure to report back here with details. The less details you provide, the less I can help.
Mar 21, 2009 | Microsoft Windows XP Professional SP2 for...
Cannot get comp to install resource cd
pls take out all pci cards and have u installed AGP for VGA instead of in built tell me the make of ur vga , i think i can help u in this the first blue screen thing u were facing was not ur motherboard infact ur RAM u have changed it it should be gone even on ur old system, u have also changed the hard drive it has nothing to do with freezing thing u were facing ok
tell me how many pci cards have u installed in ur system and what abt VGA is it in built on mother board or additionally fixed by u , actually something is faulty and it is causing u trouble in hardware kindly do this
take all pci cards out modem , sound,tv card
use new RAM chips
just install RAM and VGA to start take out all drives like dvd or cd just leave one for installation the newest one
u can use ur old hardrive or new i dont feel it is ur hard rive
and then try to install OS without pci cards if u have
check the CPU fan is it running and also check the Casing Fan also
pls tell me the results
if not resolved tell me the whole config of ur system what u have inside
i can solve ur problem if u want
regards
Feb 28, 2009 | Dell Dimension 4300 PC Desktop
Error 7 xp reboot
That's strange because that is how you install xp, from the operating system disk, maybe it is a bad disk, let me look up those errors, http://forums.techguy.org/hardware/620187-solved-cannot-boot-cd-code.html
check this out it's the same as you describe
Dec 21, 2008 | Dell Dimension 8400 PC Desktop
ValuSoft's "Complete Bible Collection"
Have you tried to boot into Safe Mode? if you can do so successfully, you'll have a good chance of being able to undo some of the damage. Did you create a system restore point before the install?
Sep 28, 2006 | ValuSoft Bible Collection (10281) for PC
Dell Dimension 8400 PC Desktop Logo
911 people viewed this question
Alun Cox
