Question about Cuisinart DFP-14BC Custom Food Processor
Motor switch not activating on a dfp-14ts
Purchased a used dfp-14ts cuisinart food processor. when all parts are assembled, the white plastic rod on the bakc of the bowl does not depress the switch to activate the motor - does any one know how to fix this? is it broken, or just a part replacement?
    Problem Solver:
  • 17 Answers
Is the cover assembly engaged and locked into place? If you can't lock the cover into place, it's possible that part of the plastic on the cover assembly is broken and not engaging the white rod inside the bowl. Determine which part is at fault (either the bowl or the cover assembly) and replace it.
Posted on Dec 28, 2008
Why Cuisinart mixer will not start?
All Cuisnarts have an interlock rod built in to the bowl assembly.
Make sure the bowl is positioned on the motor base correctly, and the actuator in the lid that pushes the interlock rod down is not bromen or damaged. If it is intact and working correctly, then check the switch it pushes on, or the main power switch.
May 20, 2014 | Cuisinart DFP-11 Deluxe Food Processor
Wouldn't start:
Repair or replace is the simple answer but sometimes innovative solutions work just as well. The plastic piece-switch combination ensures that the machine cannot be started unless everything is in place properly.
Nov 24, 2013 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart DFP-11 Deluxe 11 Food Processor Motor Shaft Cover is broken. Can this part be replaced by the user? What part number is required? The manual does not provide this information and the processor...
You can get the Motor Shaft Covers for most if not all Cuisinart models from their customer service. They are not shown on the web under parts, but if you call them, they can help you get the right part. Just have your model # ready. For many, the part is $3 plus shipping and handling.
May 13, 2010 | Cuisinart DFP-11 Deluxe Food Processor
Won't start
Make sure the work bowl handle is locked in place so that it is facing the front of the processor (same side as the on and off switches).
Make sure the feed tube of the lid is facing toward the back of the processor and that the plastic or metal rod of the pusher sleeve is facing the back of the processor.
Note: this assembly only applies to the Cuisinart DFP-14 series - every Cuisinart has a slightly different assembly for it to turn on.
Sep 13, 2009 | Cuisinart DFP-14BC Custom Food Processor
My Cuisinart food processor won't start!
Make sure work bowl handle is locked in so that the handle is facing the front of the processor, and that the feed tube and metal rod of the pusher are facing the back of the processor. If it is assembled in this way and still won't turn on, call Cuisinart for assistance, as you may have concelaed damage to one of the work bowl parts. 1-800-726-0190
Jul 27, 2009 | Cuisinart DFP-14BC Custom Food Processor
Machine on but not working
The video is generic, and may actually show a different model with completely different assembly instructions. For the DLC-8S and DFP-11 series, you want work bowl handle facing the front of the processor, feed tube on lid facing back of the processor, and sliding lock switch facing the front of the machine. For the DLC-2011, you want work bowl handle facing front, lid lined up with work bowl handle, and metal element hanging from pusher facing front.
To make sure the motor is working first, remove the work bowl, blade, etc. completely from the base of the food processor. Plug the base in and turn the food processor on. Then use a pen to press in the dark gray or black button on top of the processor - if it makes a sound, your motor is good. If it doesn't, call Cuisinart and get your processor repaired.
-Tha Mp3 Doctor
Mar 31, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Plastic housing cracked Cuisinart DFP-11 Deluxe food processor
The Motor Shaft Cover parts are not shown on the Cuisinart website under parts, but they are available if you call Customer Service. These parts are quite inexpensive (often $3 + s&h). Have your model number ready, and they can get the right one out to you.
Jan 03, 2009 | Cuisinart DLC-5 Food Processor
Cuisinart does, in fact, have the replacement bowl parts for the DFP-11
Jan 03, 2009 | Food Processors
Cuisinart DFP-14BC Custom Food Processor Logo
343 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
