Question about Dryers
I need to replace timer on my old Maytag dryer...
Ok the timer model number is 308088. It is expensive. My question...
Are there other perhaps less expensive timers that can do the job?
  • blindaim Dec 19, 2008
    Thanks! I have located a "rebuilt" timer online ($62.50). I'll see if I can have mine rebuilt for less money. The dryer is still brand new looking and worked great until the timer failure.
    President:
  • Dryers Master
  • 2,651 Answers
Timers are generally specific to model, you can try to find a local store that will perhaps rebuild, or sell remanufactured parts
Posted on Dec 19, 2008
How do I remove the timer from. May tag dryer
Depends on the model number. what is that model I will help,
Oct 16, 2014 | Maytag Dryers
Replacement kenmore dryer timer wires don't match up
Follow the wireing diagram to the timer and that should do it
Apr 05, 2014 | Kenmore Dryers
My Maytag "Dependable Care" dryer timer is not functioning and the dryer will not work. Will simply replacing the timer fix the problem? The washer/dryer set has been wonderful, but is about 12yrs old. ...
Don';t throw the dryer away yet. Check the circuit breaker in the electric panel to see it it has popped. If it checks out ok then check where you plug the dryer electric cord in. There may be an overload pop-out button on the receptacle. If there is, reset it.
Oct 09, 2010 | Maytag Clothes Dryer Almond Timer Knob...
The Maytag washer is 26 years old. The problem is
Sounds like the timer motor may be dead. Can you hear it ticking when it is on or can you see the gear on the timer motor shaft turning when it is running? If not then the timer should be replaced.
Jan 16, 2010 | Washing Machines
The timer was a little tough to get started sometimes, I'd have to pull the knob out and push it back in several times before it would start.
The start switch is going out. You will have to replace the whole timer on this model. Check the first 2 numbers of your serial number if it is 10 - 15 the part number is 33002855 if the first 2 numbers are 16 or greater the part number is 33002803. Please rate me after reading.
Dec 13, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Sep 13, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Dryers Logo
95 people viewed this question
Top Dryers Experts
Marvin
Marvin
