Question about Delfield 'New 6000XL 6051 Side by Side Refrigerator
Clean the condensor
I have two types of units a delfield 6000xl and a delfield mcII. On the front of the unit where the temp reading is located, it also says clean condensor. How do you perform this task and does the unit need to be shut down?
    Problem Solver:
  • 6 Answers
You can clean the condenser while it is running or you can unplug unit . most of the time you can use a nylon brush to brush off the condenser. If it has not been cleaned in a while you may need some sort of compressed air to blow through it. If units are in restaurant and by fryers or have greasy buildup on them you will need to unplug unit and spray some degreaser on it then rinse with water. It is important to clean the condenser, the part with fins and is located by compressor, because a dirty condenser will shorten the life of the compressor.
Posted on Dec 20, 2008
Delfield 6000xl: what is the 404a freon charge?
this web site has a table of units and their respective charging amounts.
Hope this does it for you.
May 09, 2010 | Freezers
this is for their web site. It has all the manuals and charging tables. There is no 6000xl. Need exact model number as the amount varies.
Hope this helps
Mar 25, 2010 | Freezers
Temperature display reading 32 degrees on delfield 6000 xl freezer unit. Should be set for 0. door has been opened one time this morning. Where is display box to check troubleshooting codes located on...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 | Delfield Freezer Series 6000XL Remote Half...
Delfield ColdPro Refrigerator, Commercial unit, two door reach in... recently has begun to freeze.... Temp setting stays at 37F and for some reason, just on occasion it will drop to 0... and everything...
Intermittent failure of thermostat is the most likely problem.
Check the temp sensor to make sure it is clean.
You can check for voltage coming out of the thermostat when the unit is working improperly.
If the setting is on.... say, 36, the temp is... say, 26, and there is still voltage coming from the T-stat telling the compressor and fan motors to operate, then you have a bad T-stat/sensor.
Most T-stats for that type unit do not have a separate removable sensor, its all one part with a sensor on a long tube/wire.
You can probably buy one from your local refrigeration supply warehouse for less than 35 bucks.
If it were a more consistent problem, I would say you have clogged coils or low refrigerant. But if most times it works fine, and then just randomly will not shut off, that's likely a controls thing. = T-stat.
Jan 02, 2010 | Delfield (F18WC60) Commercial Refrigerator
Need run pressures
You have to give more info. What refrigerant, where is the unit located so ambient temps can be considered, is there a cap tube or txv.
Try this web site from Delfield. It should be you manual. It says your unit has 404-A. Check it out and let me know if you need more info.
Dec 16, 2009 | Delfield Freezer 6125XL-S
How was this unit originally equipped? TXV? Use only a TXV OF CORRECT size. In refrigeration if you have a 6000btu rating you do not use a 1/2 ton valve you use a 1/4 ton (3000btuh) at most and would need consulting with an engineer to arrive at the correct valve.
SO was the TXV the other fellow replaced an OEM valve? If not this may be the problem as most TXV's off the shelf are designed for walk-in refrigeration Not Reach ins. An OEM valve may be the trouble here.
Now not to stress the TXV but also the compressor (what was the original model?) Make sure it is designed for the particular heat range and size for this application. As you probably know 1 size compressor designs for AC will not be OK on Refrigeration at same BTU rating.
Call Del field and verify what they are using or recommending for this unit. model and Seal no required and the existing model and SN.
Also to my knowledge a receiver is not required and in fact will only add to your trouble. Receivers are for changes (wide differences) in condensing temperature and pressure. Never saw an application for one with a condenser designed from factory for indoor use with either type of expansion device.
If you need Del fileds number email me at and in th subject line enter delfield?.
Feb 14, 2009 | Delfield 'New 6000XL 6051 Side by Side...
Delfield bay marie M/N 18693pt S/N 65629M
very most likely overcharged on freon. With R-409-A, you can not charge by sight glass. Do the ambient plus 30 method if it is a txv. That will get you close. If it is a cap tube, charge to an evap temp of about 20 degrees. then watch it. Make sure it makes temp and shuts off.
Hope this helps
Jul 14, 2008 | Delfield (F18WC60) Commercial Refrigerator
Delfield 'New 6000XL 6051 Side by Side Refrigerator Logo
222 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
