Question about Sony KP-57WS500 57" Rear Projection Television
Picture comes on then fades to blue
When I turn the TV on their is a picture. Then after a few minutes the picture fades to the whole screen being blue. But you can still hear the TV.
  • 2,336 Answers
Check the info from this website to see if you are able to fix your TV. You should turn the blue screen control down slightly counterclockwise. If that did not work, then more likely you have a video amplifier IC defective or a blue CRT.
Posted on Dec 19, 2008
Blue screen
The blue picture tube has gone bad. Sadly they are no longer availible for that unit. But the blue tube assembly can be sent back to a company called Video Display. They rebuild the tube for a very reasonable price. The hitch is that it takes a professional tv tech to reinstall and align the rebuilt tube. Most respectable shops will do this work but the repair is spendy. Usually around $450 to $500 or more.
May 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Blue screen
This is easy to fix, pull off the front grill and turn the bottom left trim pot anti clockwise until the picture comes back. I am asuming the picture there and then it fades to blue. There is a step by step instruction on how to get the whole thing apart http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture and screen
Jan 02, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-51HW40 fades to blue screen
you need change the ic in the soket blue [video out]
Aug 15, 2007 | Sony KP-51HW40 51" Rear Projection...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
KEEP FADING TO BRIGHT BLUE SCREEN
I'm about 90% sure it is the blue picture tube developing an intermittent heater to cathode short. I'm surprised the set isn't shutting down shortly after this happens. A service call will tell you for sure as it could also be a bad solder connection causing a similar symptom. My own procedure to check it out would be to GENTLY tap the neck of the suspected picture tube with a screwdriver handle to see if I could get it to come and go (Or get out my CRT tester and measure it with the power off). Obviously by holding the screwdriver blade you don't want to accidently short anything out as there is about 33,000 volts a few inches away from where I would be tapping. Nuff Said.
Feb 11, 2007 | Sony KP-53HS20 TV
Sony KP-57WS500 57" Rear Projection Television Logo
245 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
