Question about Frigidaire Kitchen Ranges
Frigidaire plefm399dcd error
What is error f7 30 on Frigidaire plefm399dcd stove?
reg501
  • 413 Answers
SOURCE: Frigidaire Stove model # 791FEFS66DS
F10 is a Runaway temperature issue.
There are three possible scenarios:
1. The temperature sensor has failed.
2. The electronic control has failed
OR
3. The connector between the temperature sensor and the electronic control has failed.
The connector can be troublesome. The first thing to do is eliminate this potential issue.
  • Remove the back panel.
  • Locate the temperature sensor plug
  • Cut the plug off the temperature sensor wires and the corresponding electronic control wires
  • Using ceramic wire nuts, secure each temperature sensor wire to the corresponding electronic control wire.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Posted on Jun 21, 2008
SOURCE: Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Posted on Jan 02, 2009
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
SOURCE: Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Posted on Apr 22, 2009
DeBruce
  • 145 Answers
SOURCE: black enamel stove top,frigidaire
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Sep 28, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Error Code E0 39 after replacing induction Control module. Our Range is Frigidaire CPCS3085LF, apparently the module is not talking to the panel. is there a fix?
Execute following sequence to force cooktop reconfiguration (Be sure the good ESEC20 UIB is installed into the cooktop)
1-Put all rotary control to the first detent position clockwise (1 o'clock).
2-Put all rotary control to the first detent position counterclockwise (11 o'clock). The system should then reconfigure, showing walking dashes on the cooking zones displays.
3-Put all rotary controls to "Off" position. There should be no more error code and the cooktop is ready for operation.
Frigidaire Range Stove Oven Surface Element Board 318329620 Frigidaire Range Stove Oven Oven Control Board 318347100
Jun 12, 2016 | Frigidaire Kitchen Ranges
Power surge made my Frigidaire stove show a F9 code
F9 is a door lock error. Sometimes when the power surges the door locks then unlocks. It is possible your door lock could actually be broken, however many times when the EOC fails, it will show an F9 when it should show F1. I would guess that your EOC (main computer board) is fried. Try unplugging it for 24 hours then press the door lock button once you plug it back in. If there is no error code when you plug it in but the error code comes back when you lock the door, you probably have a problem with the lock.
Jun 25, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire stove door locked f30 error code
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. Try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, contact a professional to move forward accurately
Nov 25, 2012 | Frigidaire FES367 Electric Kitchen Range
Frigidaire gas stove beeping
Most likely the control board, is it showing an error code of any kind?
Nov 17, 2012 | Frigidaire Gas & Electric Stove/Oven/Range...
FRIGIDAIRE STOVE
F1 is a EOC (electronic Oven Control) failure... you will need to repace EOC
Aug 29, 2008 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire CPL-EF398DCK
If unplugging doesn't reset it, then EOC electronic oven control is most likely defective
Nov 15, 2017 | Frigidaire fes365e Electric Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
