Question about Philips 55P8341 55" Rear Projection Television
Philis tv I am trying to reset hour meter on my tv and I don't have the manual book or remote, please help. Thanks Bonnie
  • Easy Chair Mar 20, 2008
    On Philips cineos projo can't get rid of Replace the lamp and Reset the hour meter message. Have replaced the lamp. Have reset the hour meter many times. Have opened and closed the door. Unhooked the power cord.
    Genius:
  • 1,074 Answers
To get a originald remote for your tv go www.partstore.com they will be able to help you.good luck
Posted on Mar 30, 2007
  • 944 Answers
Go to this link; http://www.usasupport.philips.com/productDocuments.html?ProductCode=55P834199&subCat=STANDARD_PROJECTION_TV_SU_US_CONSUMER they have the manual, troubleshooting, FAQs etc. I think pages 13-19 should explain what you need. Unfortunately online Philips do not still sell replacement remotes for this set, contact them for more info, they should have an alternative replacement available; http://www.usasupport.philips.com/casesubmitbridge.html?ProductCode=null Hope this helps, please post again if you need more info :)
SOURCE:
Red lamp lite on and how to reset lamp hour meter?
turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
Jan 29, 2010 | Panasonic 52LCX1516 52 in. Television
How do i reset the hour meter on my panisonic
RESETTING LAMP HOURS
Consult Your owners Manual but this works for most Panasonics
Turn on Power
Press and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 23, 2009 | Panasonic Televison & Video
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
May 29, 2009 | Panasonic PT-50LC14 Television
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
High def tv: We replaced the lamp unit, but don't know how to reset hour meter
turn the TV power on the projection display or remote control.while pressing the volume button on the projection display hold down the PIP or split button on the remote control simultaneoulsy for more than 5 seconds.
Dec 30, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
