Question about Dell Dimension 2400 PC Desktop
Capable of upgrading more?
I have a dell dimension 2400. my hard drive crashed so i put in a 350g new drive.(i cant believe i did it and it actually works). i have a Intel(R) Pentium(R) 4 CPU 2.40GHz. 2 gigs of ram.
my question is, can i or should i upgrade the processor to a core 2 duo. this is greek to me but i am learning. my goal is to put a tv tuner in the computer but i dont think i can now with that antique processor. i also want to install a dvd burner with light scribe...eventually.
since i crashed the computer and put a new hard drive in it, it seems to be running very well and i am very happy with the speed of it now. i just want to upgrade the thing instead of dropping 800 bucks on a new one. i fig i could add little by little ya know...thanks
  • 24 Answers
Well i would say you really dont need to upgrade everything is cool with your computer really so it would just be a waste of money
Posted on Dec 19, 2008
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
Dimension 2400 freezes with new hdd
That's because the diags were located on your old hard drive on a different partition of the hard drive.
Mar 16, 2013 | Dell Dimension 2400 PC Desktop
On dell dimension 2400 desktop Primary Drive 0 not found. When I hit F12 it does nothing. I can't get to the Diagnostics page.
More than likely your hard drive has crashed. You'll need to replace it and reinstall the operating system.
If you'd like to try and mount the drive to recover files, I'd recommend downloading and burning ubuntu onto a cdr and launching the live version (advice for advance user)
If you'd like a Pro opinion I'd recommend finding a local repair shop that does FREE diagnostics.
Hope this info helps!
Oct 10, 2010 | Dell Dimension 2400 PC Desktop
What to do after installing a new hard drive?
Download and install the drivers from
Install them in this order
Apr 04, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension boots up but window page wont up just goes to system information page and at the bottom it for set up, to continue...i press contiune and it comes back to this site --i replaced...
It sounds like it is stuck in the windows loop, you will need to reinstall windows fresh thismeans you will need to format the drive as well
You say you have replaced the hard drive, are you referring to the actual physical component as alot of ppl confuse the base unit for the hard drive, if so did you format and reinstall windows from scratch?
I believe if you do as i described above it will clear the problem
Please leave feedback/vote if my answer was helpful
Feb 10, 2010 | Dell Dimension 2400 PC Desktop
Upgrades and advice!!!!!
2GB is the maximum amount of ram you can install in your Dimension 2400. Depending on how much ram you have in it now,.. you could get a substantial speed difference by upgrading. You can upgrade the video card if you want. If you want to upgrade to 2 GB and upgrade to a decent vid card,.. you are looking at about $180 for parts. you will need to determine if that is something you want to put into the 2400 or buy a new computer with substantial speed and performance difference for about $500 from Dell. If you have any further questions, please post a comment here and I will answer them for you.
Feb 08, 2010 | Dell Dimension 2400 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
Hard drive crashed
It all depends. Best bet is take it to a data recovery professional & see if they can recover anything for you. Hope this helps.
Feb 10, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 with secondary SATA hard drive keeps crashing
generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Jun 20, 2008 | Dell Dimension 2400 PC Desktop
Xp format problem
Assuming that you have both XP's on the drive, when it boots up, have you selected and tested both? OR
Did you format the entire drive and wipe the old system off, replacing it with the new install?
The simplest why to fix is to boot up on the Pro CD and format the entire drive and install new system. It sounds like your old info may still be there, but you can't get to it. Try the different boot option and burn your desired data to keep to a cd, then do the simplest. Don't worry about the system drivers, you can recover them from the restore cd or download them from the Dell.
The Pro XP will be able to recover your system enough to get the drivers on line.
No big deal, just time consuming.
Good Luck
Feb 14, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
113 people viewed this question
Alun Cox
