Question about Microwave Ovens
GH5184XPB 3 microwave sounds strange when starting
It does this when you have not used the microwave for an hour or so. It sounds like a fan that starts slowly and then over about 4-5 seconds gets up to full speed.
    President:
  • 2,692 Answers
Unplug your microwave. Open the back remove and oil the fan motorand clean the fan or replace the motor.
Posted on Dec 19, 2008
Started tripping circuit breaker. It's on a 15 amp circuit, we bought it two years ago and it only started doing this last week. It first did this 7 minutes into cooking a frozen meal. Then four minutes, 3...
The problem could be a failing magnetron or control board. The tingle may be traceable to a faulty receptacle installation - one with a floating ground or incorrect wiring such as reversal of the hot and neutral lines. The vibrating sound seems to be one of the quirks of GE microwaves.
Apr 28, 2017 | GE JES1358 Microwave Oven
Whirlpool gold GH5184XPB-4 Last used to cook potatoes. sensing then cooked. Now runs but does not cook. Any ideas? Joe
There are three reasons for this, a bad magnetron "common problem" or a high voltage diode and capacitor can be a factor. If the magnetron is at fault it is cheaper to replace the microwave oven.
Mar 10, 2011 | Whirlpool Microwave Ovens
When turned off after cooling for 5hr. The outside unit buzzers as if a motor is running. it has gone on for 3hr. if I turn the unit back on it works OK just the outside unit seems to keep going.the out...
Do you mean after cooking for 5 hours? If so, yes. This is normal behavior. The microwave is running an internal fan to cool the components inside of the microwave. The fact that it has done so for 3 hours is a bit strange, but I doubt there is any issue with the inverter. Watch for errors. Error F33 or F34 mean an excessive heat build up in the microwave. Errors F81, F82, F83 and F84 mean that there is an issue with power delivery, such as inverter failure. While F86, F87, F88 and F89 represent shorted contacts within the microwave's boards and power supply.
Hope this helps,
~KenjiFox
Jan 07, 2011 | Panasonic F606Y6G00CP F606Y6G00CP Inverter
Microwave makes strange sound when turned on
The fan motor either needs maintenance including lub or it need to be replaced.
Jan 01, 2009 | Kenmore Microwave Ovens
Strange rattle when microwaving
Chances are the blade assembly has come loose on the shaft of the internal cooling fan.
This can be solved with a couple of drops of super glue at the spot where the blade and shaft meet, then allow it to dry for several minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll see the cooling fan.
Please let us know what you find.
Dec 23, 2008 | Sharp R-1490 Microwave Oven
Strange sound - seems to cook too hot?
It sounds like either your inverter is producing too high a voltage, or your magnetron may be damaged, causing it to overcook. In either case, it definitely needs professional attention. There are very high voltages involved. Since it's out of warranty, the repair charges would likely run about $75-90 labor for in-home service (less if you carry it in) and about $40-75 for parts depending on which is bad. If you run into a technician who can repair the inverter instead of just swapping it, you might save a bit.
Sep 13, 2006 | Panasonic NN-S252WF Microwave Oven
Microwave Ovens Logo
136 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
