Question about Olevia LT32HVE 32 in. LCD Television
It's the 26 inch version but have problem with picture
When I first turn on the unit, sometimes the screen stays blank or goes to a ghostly white screen, after a while...about 10-15 minutes the picture will come on or in. Either way, the sound and other functions work well. Channels change, volume controls work, but there is no display to show volume or pic. By the way, this unit was purchased less than 7 months ago.
Thanks in advance,
Paul
  • Anonymous Jan 01, 2009
    I have same problem with 26 in. LCD TV, and it's been used less than 6 months.
  • 2,336 Answers
Hi Paul,
It looks like your TV might have a main board failure if the screen stays white without video. Since your TV is less then a year, I would suggest to contact the manufacturers to get fix under warranty. Most electronics devices carry one year warranty.
Good Luck.
Posted on Dec 19, 2008
Vizio Model SV320SVT powers on, after Vizio splash screen it goes blank. Power stays on, but no backlight on screen.
Yes its very repairable as long as the logo stays white you can assume the main boards good. I would recomend contacting the people at www.tvrepairworld.com by hitting the contact us button from their website. They will be able to assist you in finding out whats happening with the set for free. They have most parts available as well.
Aug 07, 2012 | Vizio SV320XVT 32 in. TV
I have a Westinghouse 26" tv SK-26H730S sometimes the tv doesnt turn on sometimes. seems theres no power. i changed the power cord same results.
Hello, it seems like you need to replace the power board on this unit, you can find the part by sending a request to parts@wde.com, please make sure to include the model#, serial#, and TW#, all located on the back of the unit. You can also ask to have a technician give you a call so he can assist you a bit more on how to go about changing the power board.
Nov 21, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Mitsu vs-5042 Works then picture goes out. Thumping works sometim
If you occasionally have a picture then you stand a good chance of repairing this tv. There are bad grounds on the deflection board. Start with the board that has the flyback. I do not know the year of your tv. Sometimes the same model may have an option improvement than one couple of months earlier. The first suspected problem would be the vertical IC. In some cases this ic is located on the convergence board and in others the flyback board. It has seven pins and is the TDA version. Located on a large heatsink. Resolder this and any other grounds on both board. Some will tell you the P I P board is bad. This is a free standing board that can be removed and replaced. But please do the earlier option first.
Jun 28, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Screen goes to black with a ghosting of the last moving image.
This is bad real bad, when this happens it means a board known as the DMD board is failing and must be replaced, the board can run about $650.00 to get it and have it instaled
Feb 07, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Olevia LT32HVE 32 in. LCD Television Logo
440 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
