Question about Acer 22" X223w LCD Monitor
Acer X223W flickers using DVI cable, but ok with VGA!!??
OK guys, i just got this monitor like few days ago!
my video card: ATI Radeon X1650SE
Running Vista, i have installed all the drivers needed and did everything! What i am trying to ask for help is that my screen flickers like every 10 minutes or so, i tried to reduce the frequency in the ATI Catalyst Center, and it's fine after, but when i restart the computer, it flickers again, so i have to do the work all over again(which go into the ATI Center and change the frequency) in order to make it not flicker, and i don't really wanna do that every single time i turn on the computer.
Anyone knows what happened???
  • chongmung Mar 19, 2009
    Same problem here.. when I use the DVI the monitor keeps flickering on and off, and especially when there is more motion it gets worse, sometimes to the point where it's black more than not. Anyone ever find a solution to this problem??
  • larimar May 04, 2009
    I have a new H243H and the same flicker happens in DVI running Win XP Pro SP3. No solution so far.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
Acer X223W flickers using DVI cable, but ok with VGA!!?? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715G2892 2 3 Acer PWTVAC21MQDL Power Supply for X223W
Posted on Nov 18, 2014
  • 68 Answers
SOURCE: Ripping horizontal lines on background
Your problem is not the drivers or hardware it is in your settings. Goto windows hardware settings for your monitor. Look down where it says refresh rate. Write that number down then go to the manufactures web site. Enter in your favorite search engine your monitor model and to to the manufactures site. Check to see what they recomend as your optimum and maximum refresh rates. Pay attention to the screen size also this plays a huge role in performance and out of sink refresh rates. Just out of coureosity are you overclocking your cpu or ram?
Posted on Sep 20, 2007
Nic61
  • 1073 Answers
SOURCE: Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Posted on Dec 11, 2008
  • 237 Answers
SOURCE: New install Acer x223w monitor
You would only need that cable if the other end requires a VGA end. Happy Holidays
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
budmrtn
  • 11361 Answers
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 31, 2011
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
I have an Acer Monitor X223w - is it capable of hooking up as a douple monitor to one computer?
Any monitor can be used as the second monitor for a computer. However, your computer's graphics card must have two outputs. Some simpler graphics cards, most on-board video chipsets and all laptops *do not have* two outputs. Please check the back of your computer for two VGA outputs, or one VGA and one DVI output (you can use it by connecting a DVI cable to your monitor, or by plugging in a DVI to VGA adapter).
If your graphics card does not have two outputs, or if your computer uses an on-board video chipset, you can buy another graphics card to replace the one you're using.
Mar 03, 2011 | Acer 22" X223w LCD Monitor
Once i connect my gt5662 to a monitor nothing is on the screen, i know the monitor is in fine condition, i realize the graphics card it came with has 2 different slots, should i buy an adapter an hook the...
Did the computer boot to a monitor before? Is this a new monitor for this computer? The GT5662 came with an ATI Radeon HD2400 PCI-e video card. There is also an onboard VGA port on the back of the computer. The VGA port should be disabled. The ATI Radeon HD2400 PCI-e video card comes with two DVI connectors. With the back of the computer facing you, you would use the one on the right. You would have to have an DVI to VGA adapter to use them unless your monitor has a DVI connector also. Hope this helps. This is what the VGA and DVI connectors look like. _498.jpgmoz-screenshot.png
Dec 13, 2010 | Gateway GT5662 Desktop PC
If i connect the DVI cable to my Video card (9200 family)and to my monitor an Asus VH222H i get a dialogue box saying no DVI signal. if i use the VGA cable everything works fine.Does this mean the card...
Make sure your monitor is set up to recieve what ever signal you are wanting via the monitor's menu. There should be an input button on the monitor to select the signal type. The connection really doesn't matter as long as you are able to use the monitor. There could be something wrong with the connector on the video card. Also make sure you are using the card and are not using the onboard graphics connection by mistake. If the problem persists it is more than likely the card.
Oct 27, 2010 | ATI RADEON 9200 Graphic Card
My acer x223w lcd monitor is flickering. When I change the resolution to 800 x 600 it stops. I have updated the driver and tried uninstalling and reinstalling.
hi, have you checked running the monitor on all the outputs? dvi? vga? flickering is caused most times by bad connections either in the video cable, or on the video board, or power board inside the monitor. i know those monitors pretty well, i'm willing to bet if you opened up the monitor and looked at the power supply board, you would probably find worn/blown capacitors. this could very well account for the flickering. electrolytic capacitors store power for parts of the circuit that require lots of power to run. when they go bad(overheat) they pop up at the top, sometimes leak a little fluid. they are replaceable, need to be soldered in, and you can find them at most electronic stores abundantly, but you should check everything else first, the video cables(dvi,vga) before opening the monitor.
Apr 28, 2010 | Acer 22" X223w LCD Monitor
Ati radeon X300 SE how to get both monitors working at the same time. Windows XP screen settings and ATI Catalyst Control Center can see only one at a time, but not both...
Use the DVI port, and the VGA port on the ATI Radeon X300SE graphics card.
If you have two monitors that are LCD, and they both have a DVI connector, use a DVI to VGA adapter for the VGA port on the ATI Radeon X300SE.
[You need a Female DVI to Male VGA adapter, such as this example,
http://www.directron.com/dviadapter.html
Turn both monitors on. Right-click on an empty spot on the desktop screen. Left-click on Properties, then the Settings tab.
Left-click on the monitor icon with the 2 in it.
Go down to ->Extend my desktop to this monitor, and left-click in the box to the left of it.
Go down to the right, and left-click on Apply.
Now go over to the left, and left-click on OK.
You should now have your desktop screen on both monitors. When you open a window on your Primary monitor, (Monitor icon 1), Left-click on the frame, hold the mouse button down, and drag this screen to the Secondary monitor.
If it doesn't work this way, drag to the other side.
Sep 07, 2009 | Computers & Internet
I have just installed a Acer LCD #X223W moniter. What do I need to do to get my speakers to work with it? Is there a missing port or do I need a new cable. This moniter has a HDVi cable but the Computer...
Did you give the correct model of the Acer monitor you have?
When I looked up the X223W monitor, I see a monitor with a DVI-D port and VGA port. Only the VGA cable is usually included in the box. If your computer has a VGA port (most older computers that came with only the video chip on the motherboard), you can either use the VGA cable or get a VGA to DVI adapter and use a DVI-D cable (purchase separately). Alternatively, check the specs of your power supply and available card slots and buy a new video card with a DVI port. If you have only a DVI port on your computer, get the DVI cable (the VGA to DVI adapter would work but isn't a good option).
If I read the specs correctly, this monitor doesn't have speakers. You should plug your speakers into the audio out of your computer. If you use the on-board audio you will see at least two jacks (microphone/line in) and audio out (speakers). Many audio cards and some motherboards come with additional jacks for surround sound so check your system information. Audio extension cables are a cheap solution if the speaker cables are too short to reach to your computer.
I hope this helps.
Aug 05, 2009 | Compaq Presario 5000 PC Desktop
Acer x223w monitor - unexplained system freezes
is your lcd has a dvi port? aside from vga? and also is your video card has a dvi port? if all these questions meet, first uninstall the driver of your video card. Then, you need to switch your cable, in order to do this, you must place the one end of your cable to the dvi port of the cpu and the other end to your lcd dvi port. and reinstall the driver again of your video card. see if it works. because there is a certain problem that vga port configuration differs from the
dvi port. that's why when playing games, especially online games. sometimes your system will get corrupted.
Good luck! have a nice day
Jan 18, 2009 | ASUS A7N8X Deluxe (A7N8X/DELUX D)...
Viewsonic vp912b lcd display will not work.no DVI
Yes you can but there should be an option in the monitor settings for DVI... Maybe if you go into safe mode and attempt adjusting settings for the ati for the dvi output, from what I hear that monitor is nice with the DVI option would be aa shame to lose that.
Dec 22, 2008 | ViewSonic VP912B (Black) 19 in. Flat Panel...
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
Acer 22" X223w LCD Monitor Logo
579 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
