Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 Intermittent Power Issue
I have an RCA D52W20 which is a little over 2 years old. After the first year of service, the HV transformer or flyback was replaced because the TV power was cycling a few times during startup but never turned on. At the time it was still under an extended warranty so it did not cost me anything. Now, warranty expired, the television will not stay on. This issue is very intermittent. Some days, it will not turn itself off at all and works perfectly fine. On other days, it will turn off after 10 mins, or 15 mins, or an hour and I have to wait a min or so before I can turned it back on (by front panel power button only). Any idea what could be causing this?
  • Dwayne Jackson Apr 04, 2007
    Additional information:
    It appears the only time I am having this issue is when turning the TV on from a cold start. The screen normally goes black a few times before actually turning off.
    Once cycling the power back on for maybe the third time, the TV will stay on for the rest of the evening with no issues.
    Any additional ideas?
    Genius:
  • 1,074 Answers
Your problem is intermitent resolder the power supply the horizontal along with the area of the flyback you could be having some lose solder also resolder.if that does not work check around in the power suply some bad cap,power regulator and even the flyback again.a check should be made on the microchip.if you cannot do it your self take the set to a tech.good luck
Posted on Mar 29, 2007
SOURCE:
52 in projection tv powers on for a few seconds then powers off. never see the screen
resolder the connections on the hv transformer. Next to it are 2 little rectangular pc mounted boxes. these are fused. replace the one that is open with 1/2 amp pico fuse. Also check this curcuit board for and capacitors with domed top and replace it.
Sep 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power light comes on and off by itself then stays off and the television wont come back on
resolder hv transformer to deflection board and check to little boxes to the right of the transformer. these are fuses. >5 amp pico fude will work.
Jun 07, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I unplugged and moved my TV.When i plugged it back in the color is off.there is plenty of yellow and blue tones but no red tones.What should be red is a brownish color.The picture is not right.
Resolder the connections on the hv transformer. there are 3 little boxes to the right of the transformer. replace the middle one. its a fuse. the value is 400ma.
Mar 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flipping picture distorted color untill it warms up
Resolder connections on hv transformer. Ther are 3 micro fuses to the right of the transformer. They look like little brown boxes. Check them . Usually the center one is open.
Sep 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a d52w23 rca less than three years old
sounds like what is know as the flyback. also known as the ihvt and yes this is a transformer. to get the correct part for rca you have to get the model extension number this will be like d52w23yx1 or yx2 or something like that. generally when we replace the flyback. we check the horizontal output because it is most likely shorted
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 52'
Most times this symtom is because the HV transformer (flyback) has failed. This part is LL008 on the deflection bd. and unfortunately this deflection bd is no longer available and the transformer must be replaced. It is possible that the HV splitter would be bad and that should be eliminated first. Unless you under stand HV and this process I would suggest that you will need a qualified service professional.
Feb 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tectronf@uol.com.br - Rogerio Franco - BRAZIL
Is this the HV Splitter mounted need the crt's? If so the Part Nomber is 263092 Have not seen this part bad in the model d52w20. Have Replaced alot of IFT Transformer ref # LL008 part # 259296. With a credit card call 1-800-326-0313 Cumberland Electronics. Sending to brazil, unKown.
                                       packman
Oct 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
234 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
