Question about Rancilio Silvia Espresso Machine
I require an 165 deg . celsius thermostat T3 / TY60R
Rancilio DOS 2005
where can I get this part ?
  • 8,197 Answers
You can get one here
http://espressocare.com/Qstore/Qstore.cgi
Good luck
Posted on Dec 19, 2008
How do you reset the thermostats on the rancilio?
Safety thermostat for rancilio silvia is on the boiler and has a red button on top.Press this button down and you should be ok.
Other thermostats cannot be reset - just replaced.
If the boiler temperature exceeds 165 degrees Celsius, this thermostat will trip, cutting power off from the element. This is done to try to prevent element damage due to overheating.
Mar 25, 2014 | Rancilio Silvia Espresso Machine
Where is the the thermostat on a 2.0 , 2000 vw beetle ? Thank you
First time you might check the thermostat operating.
Heed of antifreeze coolant temperature!!!
The thermostat location for 2000 VW Beetle 2.0L is on back of the alternator at the bottom side of the bracket.
IMPORTANT NOTE: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Thermostat checking:
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 60 Celsius Degree you still warm up the engine until the lifter (pointer) reach 80 C deg. (second mark after 60 C deg.). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 90 C deg.
3. The thermostat opening temperature is 87 C deg.
4. If the hose is already warm the thermostat is out of order.
Thermostat location, Part number: 050 121 113 C, in german - "Kuehlregle".
Remark: 87 ... 102 Celsius deg.
Price around $35:
Important note: Always replace the thermostat seal, position 7 in the above picture.
Sep 27, 2011 | 2000 Volkswagen Beetle
Heater is cold but abit warm when drivin audi a4 2005
Check & replace the engine thermostat if necessary.
The thermostat location for 2005 Audi A4 1.9 TDI, is on back of the alternator at the bottom side of the bracket.
IMPORTANT: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Thermostat location, Part number: 044121113, in german - "Kuehlregle" (Price around $25):
Important note: Always replace the round thermostat seal, position 7 in the above picture.
Please do rate my response. Thanks!
Feb 09, 2011 | 2002 Audi A6
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
What type of engine oil does a Peugeot 306 (1.6 petrol engine) need?
Engine oil specifications for Peugeot 306 1.6 petrol engine:
1. SAE 5W-40, API SH or SG, for temperatures between -30 Celsius deg. and +40 Celsius deg.
2. SAE 10W-40, API SH or SG, for temperatures between -15 Celsius deg. and +40 Celsius deg.
3. SAE 15W-40, API SH or SG, for temperatures between -10 Celsius deg. and +40 Celsius deg.
4. SAE 15W-50, API SH or SG, for temperatures between -10 Celsius deg. and +50 Celsius deg.
5. SAE 20W-50, API SH or SG, for temperatures between -5 Celsius deg. and +50 Celsius deg.
Jan 02, 2011 | Peugeot 405 Cars & Trucks
Converting negative deg F to deg C produces conversion error
If your measurement are negative use parentheses such as, (-4) degrees Fahrenheit converted to Celsius should = -20. Where as 4 degrees Fahrenheit equals -15.5 degrees Celsius. the parentheses are not needed if your measurement is positive.
Dec 20, 2010 | Texas Instruments TI-86 Calculator
How to change automatic transmission oil on 2005 audi a4
At the bottom of the automatic gearbox (tiptronic) you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up. Tightening torque is 24 Nm.
Automatic Transmission Fluid (ATF) checking:
1. Requirements for check:
1.1. Vehicle standing on level surface.
1.2. Transmission must not be in fail-safe mode.
1.3. Shift lever in "P" position, parking brake applied.
1.4. Engine idling.
1.5. Air Conditioner and heater OFF.
1.6. ATF temperature must not exceed 104 Fahrenheit degree (40 Celsius degree) at start of test.
1.7. Only ATF with designation ESSO LT 71 141 may be used. Do not use any lubricant additives.
1.8. Automatic Transmission Fluid ATF - part number: G 052 162 A2 (1 liter wrapping)
1.9. An ATF level check when transmission oil temperature is too low results in overfilling, when too high results in underfilling.
2. CAUTION: Too much or too little ATF will affect the operation of the transmission. The ATF level must be checked at regular intervals.
3. The oil level is correct if a slight amount of oil runs out when ATF temperature is between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg) (caused by increase of oil level when heated). For warmer climates, 122 F deg (50 C deg).
4. Hang filled ATF reservoir VAG 1924 as high as possible.
5. Shift lever in "P" position, engine running at idle.
6. Place oil drip pan under transmission oil pan.
7. Remove ATF filler plug (at the bottom of the automatic gearbox you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up.
8. With ATF temperature between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg), for warmer climates, 122 F deg (50 C deg), a slight amount of oil will flow from filler hole when ATF level is correct.
9. If necessary drain or top off ATF to attain correct oil level. Top ATF with filler hook from VAG 1924 ATF reservoir. Insert VAG 1924 (tool) ATF reservoir filler hook into filler hole and top off until a slight amount of oil flows from filler hole.
NOTE: Fit filler hook into one of the oil deflector cap slots placed on the filler opening.
CAUTION: Do not press filler hook upward or oil deflector cap can be pushed off.
10. Reinstall ATF filler plug. Tightening torque is 24 Nm.
Sep 15, 2010 | 2005 Audi A4
Why has my rancilio silvia v3 steamer stopped
Remove the top panel and check the 3 thermostats there, one of them tripped.
Jul 16, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
204 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
