SOURCE: 42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
SOURCE: lawn tractor will not start
It sounds like a stuck or unhooked safety switch. Make sure you have the blades disengaged first, then check the safety switch on the blades.
Please rate if this helps-
SOURCE: Craftsman 15.5 lawn tractor (917.271061) won't start
Here is a link to the manual wiring schematics on page 31
Please rate this a fixya
SOURCE: 10 year old Craftsman Lawn Tractor won't start
I had a similar problem and found that the float was hanging up on the wall of the carb fuel chamber. I sanded lightly the outer edge of the float and never had the problem again. That was 3 years ago. Having a different problem now. After setting overnight in cold weather, 20's, engine turns over very slowly even with a new battery. Engine starts, but barely. Once running, everything seems fine. After shutoff, engine restarts quickly. Next morning, same thing happens. Anyone have any thoughts?
SOURCE: 16 hp lawn tractor won't start; replaced battery
starter cylinoid is bad i almost bet
Testimonial: "Fixed it in now time. Thanks for your help."
