It has a strong connection to my router but reads "IDENTIFYING..." and never grants me internet access.
You have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
hi i have just bought a Acer Aspire 5315 on vista i wanted to put it back to factory reset but it seems that they have taken out the back up to do this can i get a disc from any were or any help i would be most greatful thanks dee
SOURCE: Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
SOURCE: Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
SOURCE: wireless internet connection
This is due to the ip settings might not be matching, please check the ip setting on your system.
and also try to ping to the hotspot using the command in command prompt
ping hotspot_ip
if it is receives the connection to hotspot is ok other wise verify the ip and the security password and encryption part.
Hope this will help you
Thank you
SOURCE: Acer aspire 5542 laptop won't connect wirelessly
GO TO START>NETWORK CONNECTION
CHECK WIRELESS IS THERE OR NOT
if not there
go to Start>Run type "services.msc"
start windows zero configuration
right click WIRELESS
properties
select wireless tab
put one tick mark in the use windows to configure.......................
ok
agin right click on wireless
view wireless network
search on wireless(leftside)
select connect
Testimonial: "Many thanks, slight difference in the names on the windows I had to open but it got me on the right track and problem solved."
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire.
Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver.
Restarting the computer corrects this issue.
hope this helps
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
I have tried a wired connection at a different location and it came up with the same problem, "IDENTIFYING..."
I ran in Safe Mode with Networking like you said and I still didn't have the ability to access the internet (same problem in Safe Mode)
ok... Do this then: Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up. Kaspersky rescue cd download:http://majorgeeks.com/downloadget.php?id... Imgburn download:http://majorgeeks.com/downloadget.php?id...
