Question about Belling XOU492 Electric Double Oven
Replacing timer unit
I am attempting to replace the timer unit but after removing all the apparently relevant screws around the top area nothing seems to come apart. Am reluctant to use too much force so am wondering if there is a trick or technique I am not aware of. Can anyone advise procedure for dismantling to get at the timer please? NOTE: If anyone is attempting this themselves then disconnect the appliance from the mains electricity source first.
  • Leslie Legg Apr 02, 2007
    Thanks for the very prompt response. I had wondered if it might be the case that perhaps the whole thing would need dismembering to achieve the objective. I am very impressed with Fixya - it's great that people are willing to share their expertise and experience in this way.
    President:
  • 1,462 Answers
If like other belling, take side panels off. take off screws holding hobtop and move it backwards. clock should be then accessible
Posted on Mar 30, 2007
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Scan pdf file ef720
I have a similar problem and contacted Stoves. Apparently the timer unit is now obsolete which means replacing the complete oven!
Jan 05, 2014 | Stoves 720EF Electric Double Oven
Replacing element
Please Turn your breaker off before attempting replacing your element.
I wrap electric tape around the wires and stick the tape to the oven wall to hold the wires in place. Becareful if they slip in the hole you have to remove the oven from the wall to retreive them.
http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Ovens
Oven will sometime take an hour to get to temp after being turned on. any thoughts?
If your oven is older or you live near the water check if there is a build up of fine rust over the burners. A fine wire brush lightly run over the top of the burners may be your solution. Before you attempt this disconnect electrical power and turn off the gas supply. If you are mechanical remove the front lower cover by opening the doors, removing the two screws located in the top of the lower cover next to the door hinges. The cover will remove to the front. Next remove the screws holding the shield in fromt of the burners. A long handled fine wire brush will allow you to brush the top of the burners. If there is a film of fine rust it will not be apparent when looking. After careful reinstallation of the burner shield and ensuring there is a safe area away from the exposed electrical connections for you. Reconnect electrical power and gas to the oven temporarily. This will alow the unit to be operated enableing you to look past the pilot flame to see if the burner flames are even across the burners. Disconnect electric and gas supply from the unit prior toiInstalling lower cover. After complete reassembly reconnect power and gas and enjoy.
Aug 08, 2011 | Blodgett DFG-100 Gas Single Oven
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
Need to replace halogen bulb that illuminates Advantium interior
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Feb 17, 2009 | GE Profile Advantium SCB2001KSS Stainless...
Replace clock timer
ok bobo lets go....always unplug unit first...pull the range from the wall,,,best if you get behind it if you can,,,now you those 8 phillips head screws around the top back of console..remove that bact console panel...now there 4 screws holding the clock in remove screws but not the wires..let the old board just hang from wires,,your close now ...put new board in there did you get the overlay with the new board ,,no..so take that flim strip overlay of the old one,,ok mount the new clock put back for screws,,,take the old clock timer connection off one by one and put on new clock ,,...you did it,,,just reverse to put together,,,
Dec 29, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Control panel disassembly
Shut the breaker off to the oven first. Frame around mircowave is a snapped on front. Removing allows access to two screws under control panal. Must actually pull entire unit out about 9 inches to access top of control area to remove access panel. Once front control panel is removed and top is opened, easy access to what you need to get to. Carefully write down color coding of wires before removing any of them. Remove old power supply board and display and reconnect. Reverse process. A bit of work but if you watch the disassembly process carefully, pretty easy.
Jul 11, 2008 | Ovens
How to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Oct 25, 2007 | Fisher and Paykel AeroTech - OS302M...
Belling XOU492 Electric Double Oven Logo
216 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Mike Charette
Are you a Belling Oven Expert? Answer questions, earn points and help others
