Question about Kenmore Elite 45986 Front Load Washer
Indicator flashing "H", "F".
Alarm sounds, washing stops. Pause and Start buttons will continue the wash cycle.
What does the flashing H and F mean?
    Genius:
  • 1,028 Answers
Ck drain hose first be sure end is at least 30-36 in from floor and fits loosely in standpipe ckd for water to both connections on back of washer ..remove top ck flowmeter on left side small round object with 2 small hoses and wires attached try taping it fixes problem replace it if not still suspect it and replace it
Posted on Dec 19, 2008
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
ERROR CODE 61
If you have Zanussi washing mashine
To enter diagnostics:
  1. Switch off the appliance
  2. Press and hold down START/PAUSE and any one of the option buttons simultaneously
  3. Holding down both buttons switch the appliance on by turning the programme selector one position to the right (clockwise)
  4. Continue to hold down the START/PAUSE and option buttons until the LED begins to flash (at least 2 seconds)
In the first selector position, the operation of the buttons and the relative Led's is checked; turning the selector knob clockwise activates the diagnostics cycle for the operation of the various components and displays any alarm conditions.
Apr 21, 2014 | Washing Machines
Hello there, I've buy zanussi fae 825 v washing mashine and now faced with problem. Mashine fill with water, then drain it off, then indicator of end of washing flashes three times, then goes out and...
First: make rapid reading of alarms
How: the appliance is in normal operating mode (e.g. while the washing programme is in operation) than:
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
The alarm is displayed by a repeated flashing sequence of the two LEDs: 1. END OF CYCLE indicator = indicates the first digit of the
alarm code (family)
2. START/PAUSE ? indicates the second digit of the alarm
code (number within the family).
After reading alarm code look down=
Could be:
E33 - Incongruence between contact closure of antiboiling and 1st
level of pressure switch.
Remedy: Pressure switch faulty; Current leakage from heating
element to ground; Heating element; Wiring faulty; Circuit
board faulty.
E35 - Water overflow.
Remedy: Water fill solenoid faulty; Leaks from pressure
switch hydraulic circuit; Pressure switch faulty; Wiring
faulty;Circuit board faulty
E36 , E37, E39 - Circuit board faulty
Dado
Jan 24, 2018 | Zanussi Washing Machines
Front loader stops mid cycle and blinks Er until start button is pressed, the cycle will continue, and sometimes repeats this scenerio three -four times each load. any thoughts anyone?
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further advice.
Jan 11, 2011 | Frigidaire Washing Machines
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Jan 21, 2018 | Zanussi FS1155W Front Load Washer
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
