Question about Techtronic Home Fencing
Ariens st 3520 snow blower..I over pulled the pull start...how do
How do i fix it ??
  • Jim London
    Jim London May 11, 2010
    Hi, Did you pull the cord out of the machine or is it that it won't rewind?
nickpower
  • 43 Answers
SOURCE: one side of my ARIENS ST928 SNOW BLOWER doesn't work
most likely you have a broken shear pin. Look on the side that works, there should be a bolt or pin through it. The side that is not working is probably broke off. Find the hole in the auger and line it up with the inner shaft and replace with proper shear pin/bolt. Shear bolts can be obtained from most outdoor power equipment shops. I do not suggest replacing with standard bolt as it can cause damage to you gear box it auger gets jammed.
Posted on Dec 19, 2008
  • 6 Answers
SOURCE: how do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Posted on Jun 17, 2009
  • 108 Answers
SOURCE: My Troy-bilt Storm 7524 snow blower goes off after 10min running
it sounds like it may be you armeture[coil], it heats up and stops.
Posted on Dec 22, 2009
  • 509 Answers
SOURCE: Only one blade turns automatically on Ariens snow blower.
There is a bolt that goes through the center of the shaft that shears off if you hit something. You will need to line up the holes of the internal shaft with the auger tube and install a new bolt.
Posted on Feb 11, 2010
roadtech7
  • 297 Answers
SOURCE: I have a Arien's ST724
Jorge, You most likley have a Techuseh 7 0r 8 hp engine. The big problem is that it does not have a stator under the flywheel to allow you to charge the battery or run lights. So the cheapest way for you to add electric start is to buy a 120 volt strter that will just bolt on. You will have to use an extension cord to use it though. You can get the starter from any small engine shop. You just need the engine numbers when you are asking for prices and availablity. The instructions are easy to follow.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 10, 2010
What are the starting instructions for an Ariens snow blower, 10000 series, Model # H5065226H
Your carb may need cleaned but you can try using starting fluid to get it going it may just need help from sitting if starting fluid doesn't work carb is probably gummed up
Nov 22, 2014 | Ariens Garden
Need starting instructions for Ariens snow blower Model # H5065226H
do you have a fuel shut off valve? if so make sure its in the open position. choke closed,prime 3 times and pull cord. if not started after three pulls open choke and look in carb for fuel delivery. if none service your carb also check to make sure you have spark before assuming its the carb
Nov 22, 2014 | Garden
Ariens 921013 has difficulty changing speed under traction. The lever wants to pull forward when I disengage it from the holding slot on the dashboard and will not let me reduce speed without disengag
It might be time to lube the shaft the bearing slides on that changes speed. If you pull the rear cover off it should be easy to spot. Some people use oil others use a little grease. I like synthetic grease as it won't drip. If you use oil remember to wipe up any excess and you don't want it getting on the flat plate the friction disc rides on or you won't have any traction at all.
Sep 13, 2014 | Ariens 921013 - Snow Blower, 120V, 30in
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
Restarting problem
Check the switch that the Lock operates.
Mar 18, 2014 | Ariens 926054 Snow Blower 2 Stage 32 In
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Ariens 30 deluxe platinum series won't start
Is this your first attempt of the season to run it? Did you totally drain and run the machine out of gas last year?
10% Ethanol gas left in a carburetor for months is a killer
Jan 03, 2014 | Ariens Snow Blower 921013 ST30LE 305cc 30"...
Ariens Snowblower flooding
remove the plug and pull it over
fix the needle and seat problem in the carby
Feb 03, 2018 | Ariens Garden
Cannot turn engine over to start. Ariens 924 snow blower
pull spark plugs and see if it will pull over if not fuel may have filled the crank case drain & refill to proper level (starter is stuck in lube shaft & movethe gear up & down by hand to free up)
Feb 13, 2010 | Sport & Outdoor - Others
I have a 7 HP Ariens snow blower Model # 910995 S # 007686. It made a popping sound and stopped yesterday. The elec start cranks but the engine won't start. Checked the engine oil, which was low and filled...
Pull the spark plug out, cover the hole with your finger and slowly pull the pull starter. You should feel compression. If not look for a blown head gasket or valve problem.
Jan 04, 2010 | RTO Sno Wovel wheeled snow shovel
Home Fencing Logo
223 people viewed this question
Top Techtronic Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Techtronic Home Fencing Expert? Answer questions, earn points and help others
