Question about DCS RGS-486GD Gas Kitchen Range
DCS stove igniters clicking
The stove was working fine, the wife said she did not have a boil over, and now if you turn on any burner all igniters fire. Do I need to change the igniter module, or is it something else. Thank you, David,
  • nitawita43 Feb 05, 2009
    All the igniters tick and do not stop. What needs to be fixed?
  • zoidzoid Feb 28, 2009
    I have the same problem--all igniters fire even after a burner is lit. Technician has been here twice. I doubt that a fix is emminent. My advise--start shopping for a new stove.
  • 10,865 Answers
Actually Dave, when you turn on one burner, all of the igniters do fire. This is normal. Perhaps you never noticed it before. regards, Joe
Posted on Feb 05, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Gene
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
MY wife boiled over her tea pot of water and now the pilots on all four burners continue to click as if you turn on the gas to light the stove.
The water has shorted out at least one of the igniter switches. Disconnect power to the unit and let it dry out for several hours and it should be just fine.
Jan 02, 2011 | Jenn-Air JED8130 Electric Cooktop
Having serious problem with the ignite. When I turn it on and its lit the clicking of the spark does not stop. Also, one of ranges will not light at all! Help.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 09, 2010 | DCS RGS-305 Professional Gas Kitchen Range
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Gas was turned off and igniters keep clicking?
As I did not see what occurred, I suspect that the tea kettle boiled over and sent water into the burners. The igniters kept clicking and I eventually turned the gas back on. Will have to replace one igniter which apparently went out and have to light it manually at this point.
Dec 11, 2009 | KitchenAid Cooktops
Clicking ignitors
Take a hair dryer and dry the spark switches located on the end of each gas valve.
Sometimes when cleaning they get wet and do the clicking thing.
If that does not correct the problem you will have to replace the bad switch.
Mar 19, 2009 | DCS RGT-305 Gas Kitchen Range
Gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Mar 01, 2009 | Stoves Kitchen Ranges
DCS RGS-486GD Gas Kitchen Range Logo
498 people viewed this question
Top DCS Kitchen Ranges Experts
Carmen Mikulic
Sal De
Ismael Rodriguez...
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
