Question about Nikon Speedlight SB-800 TTL Flash
New SB-800 died
My new SB-800 is under a month old. After a big shoot today, it died. I tried several new sets of batteries, with no luck. Did I perhaps fry something after 700+ pops? I'm DESPARATE - I'm shooting a wedding in two days!\ Help!
  • 62 Answers
CHECK THE BATTERY CONTACTS AND MAKE SURE THEY ARE TOUCHING. iF THIS IS NOT THE PROBLEM THEN
YOU HAVE TO SNED IT BACK TO THE FACTORY WITH RECIEPT FOR WARRANTY REPAIR .
'THE MAIN BOARD IS DEFECTIVE
Posted on Feb 06, 2008
SOURCE:
SB-800 makes strange noise and over exposes image when it does work
The flash has settings you will have to read your manual
the camera does the exposers not the flash
set your cameras appuatue to a high number and speed fast then shoot if you knew how to use your camera you would know the flash is uesd for filling in shadows and imitating the sun which is bright. Good luck
Feb 05, 2012 | Nikon Speedlight SB-800 TTL Flash
NIKON SB800 IN SOFTBOX
Hello..
Sporadic off camera flashes triggered with pocket wizards will not be as obtrusive as you may think. IMP, It's just as obtrusive as the onslaught of small digi cam flashes that usually occur..Cheerss!!....
Jul 24, 2008 | Nikon Speedlight SB-800 TTL Flash
Bought a Nikon Speedlight SB-600 in August. Tested the flash and it fired ok. I took out the flash a few days ago to use at a graduation and the "ready" light did not come on. Consequently it did...
Hi grwcamp, Sorry to hear about it not working at the graduation. Are in the correct position (I am sure you did but, we must start someplace). Look inside, see if there is battery acid in there.
If with new/fresh batteries it still does not work call Nikon. You have a warranty on it so it should be covered.
Nikon digital 1-800-645-6689
Dec 04, 2010 | Nikon Speedlight SB-600 TTL Flash
Won't power on
No power, no red light, no LCD, probably a faulty main circuit board, new circuit board required.
Aug 16, 2009 | Nikon Speedlight SB-800 TTL Flash
Sb 800 and sb900 overexposing
It might be you are not making a good contact on your camera and flash .
Are you using a cord to get the flash off the camera . If so the cord could be intermittent .
Jan 26, 2009 | Nikon Speedlight SB-800 TTL Flash
SB-800 Going Crazy
I think what you have is a grounding problem. I can fix this for you and please contact
Berrie Smith Camera Repair bbmw@bellsouth.net 770-312-0719
Jan 19, 2009 | Nikon Speedlight SB-800 TTL Flash
SB-800 -3EV message after about 50 shots or so
IN THE INSTRUCTION MANUAL USING THE FLASH IN SHOOTING FAST CAUSES IT TO HEAT UP .
TRY USING THE FLASH IN MANUAL AND CUT THE RATIO POWER AND USE AS A FILL AND NOT A MAIN .
YOU COULD ALSO USE TWO NIKON SB800 FLASHES IN ITTL AND WITH TWO THE FLASH IS USING HAVE THE OUTPUT AND RECYCLE TIME IS INCREASED .
DAVE BLACK A WELL KNOWN PHOTOGRAPHER DOES THIS IN HIS SHOOTING .
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
Nov 13, 2008 | Nikon Speedlight SB-800 TTL Flash
Flash blows out the image!!!
hi ,
it could be possible that the light sensor (the device under the red transparent plastic) in front of the flash is already failing. to test,set the camera mode to auto then cover the sensor with your hand and do some test shots, the images should be overexposed if the sensor is covered, then shoot some photos without covering the sensor, the images should be properly exposed , otherwise it might already be a light sensor failure .
Sep 30, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb-800 Nikon
Try Weld Bond to glue those back.
atdlee@netzero.com
Jan 05, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
130 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
