Question about Sony Playstation 3 (PS3) Console
PS 3 sound just stopped.  Still get picture, and sound works on other devices using same HDMI cable.  Tried resetting PS3 did not help.
    Problem Solver:
  • 34 Answers
PS3 is The amazing device by sony but it has some common problems like sound problem, video/picture problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Feb 27, 2009
I have a wd-62525 dlp i have pic and sound through ant. and hdmi but on component and video inputs i only get sound no pic
Hello
It seems to be some fault with its HDMI cable you connect to this device from the source. As you get sound by HDMI, and no picture at all, this indicates the fault with cable itself. There is a cution notice says that " To assure continued FCC compliance, the user must use a shielded video interface cable
with bonded ferrite cores at both ends, when using the PC or HDMI input."
Cheang the cable and check.
Oct 10, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no...
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Nov 08, 2017 | LG 47LF11 LCD TV
I am having problem setting up my hdmi connection with my panasonic viera model TH-L32C10X2. i cant get it connected to my sony ps3. all cable connections are connected. set the tv to either hdmi1 or...
I do not own a PS/3, but I will try to help just in case you dont get another expert at this late hour....
It sounds like you need to save the changes on your PS/3. It is timing out and going back to default because the changes were not saved.
Hope I helped!
VA
Feb 11, 2011 | Televison & Video
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
No sound from hdmi cable
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
PS-3 no sound
What probably happened is a problem with the HDMI cable. It must have a gouge, or an internal slash. If you get a new HDMI cable, it will work fine.
Hope this Helped.
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Picture but no sound
it happens to me alot lately i think its the actual hdmi port of the ps3 just unplug the hdmi cable and plug in and it should work just fine.
Jun 18, 2008 | Sony Playstation 3 (PS3) Console
PS3 HDMI PROBLEM WITH SOUND
I am pretty sure you need to have an Optical cable running from Your PS3 to your sound system...if you have one...
So basically you will have a HDMI cable running from your PS3 into your TV, another HDMI cable running from your TV into your sound system, then an optical cable running from the PS3 to the Sound system. I sadly own a HDDVD sound system but the optical cable tells it to accept the Blu Ray content.....
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
