Question about HP Compaq ProLiant ML330 Server
Proliand ML330 blows out feature boards
I replaced the feature board (scsi controller, video etc)and it worked for two days and now it's blown again. Anyone ever run into this problem before?
Thanks Rebel I was going to order a system board next but found another ML330 for $325.00 so I will just swap out the hard drives. It actually worked for seveal hours today and then gave me a "Hard Error" so something is heating up. Probably a cold solder joint on the system board.
Posted on Mar 30, 2007
  • 24 Answers
Assuming you are refering the feature board in a ML330 server, it sounds like it may be the system board itself that is taken out the feature board.
I have a GE JKP62G microwave-oven combo. The oven works fine. The microwave blew the 15 amp fuse. When I replaced the fuse, per your earlier directions, and tried to use the microwave, the new fuse blew....
Cause 1
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don’t resolve the underlying issue, the new fuse will blow too
Cause 2
Main Control Board
The main control board might be defective. However, this is rarely the case. Control boards are often misdiagnosed—check all of the more commonly defective parts. If you have determined that all of the other components are working properly,replace the main control board.
Cause 3
Thermal Fuse
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset—if the fuse is blown, it must be replaced.
Since its a electrical isue cal a liscenced professiona to resolve the issue . Your microwave oven isnt at fault . I belive the supplay to it has issue and would have blown anyway.
May 29, 2018 | GE Microwave Ovens
Its a Toshiba RD-XV49DT DVD/DivX/VHS Player/Recorder Combo, replaced power supply board as was blowing fuses found components have shorten out and now after replaced board, video works and i think hard...
The controller circuit (usually a small board connected directly to DVD drive - it is either part of the drive or a sub-assembly which is attached - and contains several ICs and small capacitors and a lot of surface-mounted components on its copper side) is probably faulty, possibly due to the original bad PSU (which you have since replaced), chances are the original faulty PSU has damaged this circuit - usually DVD drives operate around 12V DC or so. The digital controller circuit/board not only has the EEPROM/CPU etc. on it, but also has a servo supply - for the DVD (the VCR servo supply is on the motherboard). This powers the disc tray and traverse unit. The controller is not serviceable at component level; it must be replaced and in some cases, the DVD drive must also be replaced where the board is not separate to the drive. This may not be economical.
It may just be a simple case of a blown digital controller circuit - but be warned, this board is not cheap - it is part of a 'module' (the disc drive and controller together = DVD module), and you may not be able to obtain the board without a new DVD drive. Up to you what you do from here, and you might be lucky in terms of the motherboard and HDD - no damage there.
Apr 11, 2011 | Toshiba Televison & Video
Need the pin settings for scsi led header for intel sever board s875wp1-e
SCSI Hard Drive Activity LED Connector
The SCSI hard drive activity LED connector is a 1 x 2-pin connector that allows an add-in SCSI controller to use the same LED as the on-board IDE controller. For proper operation, this connector should be wired to the LED output of the add-in SCSI controller. The LED indicates when data is being read from, or written to, both the add-in SCSI controller and the IDE controller.
Test the 2 pins using a multi-meter to determine which is + and which is -. Nowhere in the manual does it say which is which.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 11, 2011 | Intel S875WP1-E Server Board Motherboard
Picture went black but you could still hear the movie
Hi- My PL4260N stopped working after about three years, the audio worked but no video at all. The TV worked fine until one day...no more picture.
I found out that the YSUS and ZSUS boards in the TC fail alot...BUT you can get new or repaired ones off of EBAY...
First check for failed components (burned, loose, bulging, etc.) if nothing obvious is failed then check the fuses on the YSUS, ZSUS, and power supply boards...usually if a board has a blown fuse the board needs to be replaced...get the part number and search it in Google and eBay and you will find options for replace/repair.
Mine had a blown fuse on the YSUS board...I got it fixed for $75 through coppell TV (they are on Ebay)....
Now my TV works fine again!
Good luck.
Dec 19, 2010 | HP PL4260N 42 in. Plasma HDTV
My hp plasma tv lost it's picture. Audio works fine. Work are some causes of this?
The T-con board, the board that sit right in the middle of the center LCD panel . That board is dying. try websites like shopjimmy.com, Ebay.com to buy a refurbish T-con board for replacement.
Thanks for using fixya
Aug 20, 2010 | HP PL4260N 42 in. Plasma HDTV
Blown electrical board
If this is a new machine you still have a warranty.
Contact Brother with the date of purchase and what happened.
Mar 18, 2010 | Brother CS6000i Computerized Sewing...
Scassy Card for Compaq Proliant ML 330 is defective
You cannot find the details of OEM of this card unless it is written on the card itself.
The card is HP/COMPAQ - SMART ARRAY 532 DUAL CHANNEL ULTRA160 SCSI RAID CONTROLLER CARD WITH 32MB CACHE.
If you want to use a different make card. You can safely go with a adaptec make card.
Cheers - Parveen
Feb 05, 2008 | Computers & Internet
MAH5500BWW model fuse blown
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Dec 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
HP Compaq ProLiant ML330 Server Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
