Question about Arris Wireless G Broadband Router (wr850g)
Motarola VT2542 Wireless Router: If you disable the wireless on the router's software does that stop the router from broadcasting rf frequency? I would like to use the router as a wired router without rf frequency in the house...just enternet wires into the router....
    Genius:
  • 1,269 Answers
Hi! It's ok to disable the wireless broadcast of the router however, it wont stop the router from broadcasting the wireless frequency. It will only hide itself from the people who are trying to connect to a free signal that are available.
Posted on Dec 19, 2008
How to use router without using wifi in belkin n150
This model Belkin wireless router has 4 LAN ports so you can connect a LAN cable from this wireless router to your computer.
I suggest you disable the wireless in the router so no one can access your network and Internet. If you cannot disable the wireless then you can setup WPA2 encryption to secure your wireless network or just remove the aerial off the wireless router.
Mar 05, 2013 | NetGear WGR614 54 Mbps Wireless Router -...
Can not install software???
I find the built in windows software normally works fine, But it was probably disabled when the software was installed.
You can either plug into your router with an Ethernet cable and download the new software or enable the windows wireless.
To enable the windows wireless configuration right click the WIFI connection and go to properties ,wireless networking tab and then check the top box saying use windows to configure my wireless network settings.
Jan 25, 2013 | D-Link dlinkgo Wireless N 300 Router...
F5D7634 Belkin Router how do I disable wireless option
1. log into the router and click the "wireless" and uncheck the radio brocast.
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Turn off the wireless
Login to the Router and then disable the Wireless Radio from the Wireless Settings option to turn OFF the Wireless signal/network.
Oct 05, 2009 | Actiontec (GT704WG) Router
Can't connect Toshiba laptop to Linksys Wireless Routher!!
If this is a new router then the wireless is turned off by default. You need to log on to it and enable it. Don't forget to turn on security such as wep or wpa. Your toshiba should be able to see the ssid or id that each wifi broadcasts. It will also or should be the strongest signal you see.
If the router is older and the wifi is enabled then make sure that the security setting match on the toshiba. ie wep/wpa key. If it is more than about year old then you can have a failure of the wifi section. That means replaceing the router ( I have a stack of different brands all about 1 year old with a dead wifi section).
Aug 21, 2009 | Linksys Wireless-G Broadband Router
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
How to turn Edimax wireless router to wireine router?
Open up your web browser and go to 192.168.2.1.
At the log in screen enter: user name is “admin” and the password is “1234.
Click on the wireless link on the left hand side
Select disable wireless
Click on apply
You have disabled the wireless
Mar 24, 2009 | Edimax BR-6216Mg Wireless Router...
3com Router and Panasonic BLC30 wireless camera
The solution I used was. I had a second router/ap that was wireless.
I then associated the #2 router/ap to the WPA main router,
And ran the Camera on wired mode thru the 2nd Router.
When you use an ext renal wireless AP that camera.
You get much better range. I had a che-po router.
And the range was 3x what it was using the cameras antenna.
Also Here's a back door to Panasonic FTP with all the camera related software they put out,
ftp://ftp.panasonic.com/pub/Panasonic/cctv/downloads/
Sketchlab.com
Dec 30, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Unable to change user name and password on motarola router
Are you using admin for the username and motorola for the password.You must have the i.p right or you woudn't be that far along.
Nov 28, 2008 | Arris SURFboard SBG900 Wireless Router...
Arris Wireless G Broadband Router (wr850g) Logo
323 people viewed this question
Top Arris Computers & Internet Experts
Greg Ulan
Robbie Goodwin
RS Technology...
RS Technology...
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
