Question about Acer Aspire 3000 Notebook
How do i replace the optical drive in my acer aspire 3000 laptop?
My dvd disk tray is stuck and does not work. if you could explain step by step with pictures i would appreciate it. also please include where i need to unscrew in order to open it. thanks
  • 50 Answers
I have a small tutorial on youtube about memory and hard drive the basic are the same ill post a tutorial in soon ,however to let you know there are a lot of screws and they are tiny things too! by looking at it on the left hand side there are 4 screws that hold it in place then you should be able to just slide it out, im not sure exactly how but ill figure it out and post the tutorial on toutube youll be looking for acer 3000 or zoomietime ill post it later today-z
Posted on Feb 25, 2009
Acer aspire 7741z optical drive not reading
Try Using a cleaning disc in the drive. If still not working, drive broken, replace.
Sep 05, 2012 | Acer Aspire 7741z
Dvd is stuck in my ACER laptop how can I get it out
The Acer 5610 has an emergency eject hole to the right of the eject button on the right side of the computer. Find a paperclip and unfold it (or small allan wrench), push the end of the paper clip into the hole until you feel pressure. Press firmly and the optical disc tray should come slightly out of the machine. Grab and pull the tray out (gently). This should work even without power to the drive on any machine tray optical drive, if the tray mechanism is undamaged.
For a slot-loading optical drive, it's a bit trickier. You can try sliding another object into the slot and using it to pry or lift the stuck disc. The safest option is to use another optical disc or credit card sized item and double-sided sticky tape. Put a piece of the tape on the item and then remove the paper from the other side of the sticky tape. Slide the item into the drive with the sticky tape towards the stuck disc (down for most computers). Once far enough into the drive, lower your item and press the tape firmly onto the stuck disc. Lift up and try to pull the stuck disc up and out of the drive.
I hope this helps.
Oct 26, 2011 | Acer Aspire 5610 Notebook
My laptop aspire 5740 is not able to read the dvd & cd...so i am not able to installed any softwares though cd & dvd..please solve the problem..
Try opening your disk tray and cleaning the lens with a tissue and all of the drive from dust. If it still won't read you may have to buy a new optical drive as your current one has broken.
Have fun :)
Aug 21, 2011 | Acer (KV.16X04.007) DVD Drive
Help my dvd drive is stuck and wont open
Desktop or Laptop computer wasn't stated.
With most desktop computer optical drive's there is a tiny hole located right under the optical drive tray.
(The tray the disk is inserted in)
A paper clip is straightened out, then inserted into the hole.
This is a manual override, and will open the tray.
There are some desktop computer optical drives, that the computer case has a door that flips down, then the optical drive tray comes out.
The door must be eased down far enough to see if the optical drive has the small hole.
With a laptop computer the optical drive is removed from the laptop.
Generally there is one small Philips head screw that is removed from the bottom side of the laptop, then the optical drive tray is opened with the paper clip, and the optical drive is then removed by using the tray as a handle.
The optical drive is then pulled straight out.
Once out the top cover is removed for access to the disk.
If this information is not what you seek, or you would like it explained, please post in a Comment, and we'll work together on finding a solution.
Regards,
joecoolvette
Apr 21, 2011 | HP Compaq Computer Speakers
I have an Acer Aspire 3000. After this computer
Replace disk drive, But first ensure the BIOS settings are correct. & try the drive in another machine if possible. If it is proved faulty, then replace drive with the same size.
Jan 31, 2010 | Acer Aspire 3000 Notebook
Upgrade acer aspire 3000 optical combo?
Yes you can Upgrade by changing the whole device to a DVD writer.
Mar 20, 2009 | Acer Aspire 3000 Notebook
Replace a cd/dvd drive on my Laptop
Not possible at all. To install XP or Vista again, you need a CD/DVD drive working. (or) Contact Aspire(or local technician) if they can ship a XP/Vista pre-installed Hard-disk.
Jan 12, 2009 | Acer Aspire 3000 Notebook
Aspire 3050 laptop
I've taken a lot of drives out of laptops and usually they are easy to remove and just have a button you need to press to pop them out or they are held with a single screw underneath around the center back of the drive. Those two possibilities should have you covered, and I have rarely found optical drives to be difficult to remove from laptops.
Sep 24, 2008 | Acer Aspire 3000 Notebook
CD DVD
check your lense ,clezan it with lense clener cd.
replace your lense if u have warrenty.
Apr 01, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
