Home | CMB | Software T43 750 512/60 14 GN/WL F WXP (88... | I have a laptop , and...
CMB Software T43 750 512/60 14 GN/WL F WXP  PC Notebook
Problem for CMB Software T43 750 512/60 14 GN/WL F WXP (882861029921)...
I have a laptop , and it suddenly stopped working,i mean when i on it, i can only see a black ....
By Ranny - usenet poster
i have a laptop , and it suddenly stopped working,i mean when i on it, i can only see a black screen with the letters. thats all it doesnt even load the bios, what can i do?
Same Problem
Apr 02, 2009
-   my computer clock does not work It is XP -   Guest
Mar 08, 2009
-   I have the same problem. There is a white link blinking on top of the screen too. I tried removing my batter and stuff but it doesnt working at all. -   Guest
Sep 02, 2008
-   I have the same problem with my hp,,won't power up to windows xp. Just shows the dark screen and dos writing. Did you ever fix yours?-   slowrus
Aug 27, 2008
-   My laptop will turn on and then the screen goes black but I can faintly see what should be showing in the background. If I click Fn, F6 it will turn back on for a few seconds....only to turn black again??? -   gzyzf
Jun 21, 2008
-   compuetr, able to get into when press F8 button ,but none of the options i select work? my cd-rom- set up , dont work either. it shows error file missing or corrupt. \windows\system32\config\system. -   thillyrd
Best Solution
posted on Mar 14, 2007
Very Helpful)
nucleous
Rank: Apprentice
Rating: 100%, 2 votes
I had a similar problem, my laptop wont start I get a black screen and it does not even go to bios, battery charges up ok,
removed the battery as suggested by duke, and this worked, but on the second day the same situation arises, what is up, can u help further with trouble shooting, post and send me a copy to kombo@ims.udsm.ac.tz
Was this helpful?
Yes
No
Solution #2
posted on Aug 05, 2008
Helpful)
luxuning
Rank: Guide
Rating: 85%, 2 votes
okey,Ranny, you'd better work with your AC/DC adapter connecting to your laptop,for most battery such as toshiba pa3383u-1brs,has the common phenomenon of power suddenly shut down,that is because the PCM panel of the battery bumping of disorder electric current.lead by high temperatur etc.so work with your laptop adapter as much as possible.
Was this helpful?
Yes
No
Solution #3
posted on Mar 28, 2008
Helpful)
wunnuwoman
Rank: Apprentice
Rating: 85%, 1 votes
lastnight, There is a game my son was playing and it froze.
I was trying to get the volume down but it wont do anything.
So I have to unplugged the laptop.
Now it has blue screen
STOP: c0000218{registry File Failure}
The registry cannot load hive (file)
/systemroot/system32/confi/software
or its log alternate.
It is corrupt, absent, or not writable
Colection data for crash dump...
Intitializing disk for crash dump....
Beginiing dump for physical memory...
Dumping physical memry to disk: 100
Physical memery dump complet.
Contact your system adin or technical support group for furthur assistance
I'm just writing what I see onthe computer. what can i do???please help me
Comments:
Mar 28, 2008
- I restart it and it says, Windows error Recovery
Windows failed to start.
Was this helpful?
Yes
No
Solution #4
posted on Aug 08, 2005
Somewhat Helpful)
Duke
Rank: Apprentice
Rating: 0%, 0 votes
Try removing the RTC battery (real time clock) and hopefully (for you) this is what is also keeping the CMOS memory. So, take theat out, wait about 15 minutes, put it back in, reboot and tell us your resutls.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Mar 13, 2008
Somewhat Helpful)
nightshifter
Rank: Wiz
Rating: 80%, 33 votes
Try to do a powercycle first - take the AC and battery out of the computer, and external devices connected to it. Once you see the Toshiba logo, hit F8 to try to boot up to Windows. If unsuccessful, try loading the OS using the recovery media. If all fails, repair is the last option.
Was this helpful?
Yes
No
Solution #6
posted on Jul 26, 2008
Very Helpful)
ghoff1
Rank: Guru
Rating: 94%, 400 votes
try and reset the bios check user guide for your specific model.on how to do this.or you can take the rtc battery out,then wait at least 60 seconds.most of these batteries are soldered on,so be careful! this usually works unless there is damage to mainboard.good day people!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #7
posted on Sep 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i noe
******* hell
i am half way in playing FIFA 07 and it stops
Solution #8
posted on Jun 24, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
removed the battery, tried that, dont work
Solution #9
posted on Jan 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
For many notebooks (including the Gateway 4024GZ, like mine), the LCD backlight can go out. This is commonly caused by an internal component--the inverter--faulting out.
If your notebook's lighting comes on (power light, hard drive indicators flashing as if the system is booting), then this is likely the case. You can find inverters online, but you must buy the exact type specific to your laptop. Your best bet is to use a search engine to determine the part number that you need (search for [your make & model] "inverter").
Depending on your system, these parts can be a little expensive, and they're not the easiest thing to install--but it can be done.
Solution #10
posted on Sep 23, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same thing happened to me and I took out the battery and the plug for the AC power, waited less than 5 minutes and rebooted ... worked like a charm
Solution #11
posted on Jun 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You can also try unplugging the AC adapter and removing the battery then holding down the On/Off switch for 3minutes.
If you do end up removing the CMOS battery as suggested by "Duke" you wil most likely have to remove the keyboard. Check HP's site for the Hardware and software PDF's for your system.
Popular Solutions for CMB Software T43 750 512/60 14
Questions and Unsolved Problems for CMB Software T43 750 512/60 14
Do you recommend CMB Software T43 750 512/60 14 GN/WL F WXP (882861029921) PC Notebook?
Answer
Answer
On my Acer Aspire 5810T,there's a white screen on start up,then after 10 mins or so,it goes to... (More)
Answer
getting error message and windows will not load. How do you reinstall windows on the ACER AOA 150 -... (More)
Answer
Which driver to download and where from free download Cannot get to recognise any that I have uused... (More)
Answer
i changed the grapics card setings to be able to play dvd but now the screen is black but the... (More)
Answer
Hi Everyone, Am facing a strange problem. I have a Dell Inspiron 1000, 2.2Ghz Celeron processor,... (More)
25 Other Users Have The Same Problem - Continued
Comment by T3Armagetron, posted on Jun 16, 2008
I am happy to finally found questions, which are near the same than mine.
I think I have got the same problem as mttchelle posted on June 01, 2008:
"i got problem on my laptop! when i turn on the power botton theres a light on! and suddenly stoped working and i heard some 3 times beep! please help me as soon as possible thank you! "
If I turn my laptop (Acer Aspire 9302 WSMi) on it seems to work properly, I mean the sounds of ventilation etc., the light signs a.s.o.. But I can also hear after approx. 5-10 seconds a longer beep and two shorter beeps and the screen stays black.
- I tried out with restarting (Shut down with power button).
- I also did same with waiting a while between the start ups.
- I also did with lithium-Ion-battery taken out.
- I tried several Fn+* button-combination, which could shut down the screen.
I hope someone can give more advices, I will try what duke proposed (again).
I hope my English is not too bad,
See Y'all
Comment by Guest, posted on Jun 16, 2008
See Y'all
Comment by mttchelle, posted on Jun 01, 2008
Comment by zhangdong, posted on May 11, 2008
my laptop can not start. there is only black screen when i switch on the power button .and the power button light is on . i connect the another monitor after i switch on the laptop . but there is still nothing coming out on the screen . i think it is not the problem of the monitor. can you give me some suggestion ?thanks !
Comment by Guest, posted on Apr 20, 2008
I have only a mesege on F12 Please enter a disk and upgrade bios
Comment by Ricky106, posted on Mar 18, 2008
Asus A9RP Laptop suddenly will not power up. Tested...Power adapter ok. Battery ok. Some power on mobo. Fan is not working or hard drive not powering up. No video display either.
Comment by Guest, posted on Mar 16, 2008
I have a problem with my acer extensa 4620z, when i turn it on, it has no display and there's no activity on hardisk light indicator, what will i do?
Comment by JamSket, posted on Mar 14, 2008
I downloaded a program (valid website) and a few minutes later my computer froze. I had to turn it off (with the button) and it never came back on. It starts to the point of the NASCAR logo, then it goes black and then a lot of white letters. I should be allowed to install programs on my computer. It's only a year old. How can I get it working again?
Comment by lex8999, posted on Mar 11, 2008
If i turn on my MP-XP the led´s of the keyboard starts blinking and the hdd spin up and the fan of the cpu spins time to time short. nothing else. CMOS battery is replaced and bios is reseted. whats up with my notebook what could i do ? if i remove the hdd ,nothing. if i remove the additional ram NOTHING. what could i do. I LOVE THIS NOTEBOOK. pls help me thanks
Thomas Lengyel Germany
Comment by jaeric, posted on Mar 05, 2008
when it on, i can only see a black... windows 32 programs not found
Comment by GOONERTEL1, posted on Feb 28, 2008
LAP TOP HAS BLACK SCREEN AND JUST SAYS THE WORDS .. OPERATING SYSTEM NOT FOUND
Comment by Guest, posted on Feb 19, 2008
laptop stopped working and only 1 and half month old
Comment by Guest, posted on Feb 10, 2008
My laptop just shut off on me one day, and now I can't get it working. It starts fine when I power it on, but there is no display whatsoever. What do I do about this?
Comment by Robert1379, posted on Jan 04, 2008
I have a Dell Inspiron 5150. The screen suddenly went very dark where I can barely see anything. It is 4 years old and already had a new board put in. Is it time to throw it out or is there an easy fix? Thanks
Comment by Guest, posted on Dec 18, 2007
Notebook powers up, but I have no display
Comment by clairek58, posted on Dec 15, 2007
I dropped my laptop and it worked after that but then wouldn't boot up after being turned off. Now it gets stuck when it starts loading at the manufacturers screen beeps and tries again. I can get in to bios but but no further than that.
Comment by xanxac, posted on Nov 25, 2007
my HP Pavilion zd8000 stopped working. I am able to run windows but that is all it does. After windows starts it somehow blocks and some of the programs like zone alarm don't even run.
It allowed me to backup some of my smaller files. Anything bigger then 5MBs cannot be copied to an external drive.
i tryed to install avg's spyware but it is runing so slowly that i doubt it will do anything to solve the problem.
Thanks for any help
Comment by yuvin, posted on Nov 22, 2007
When I turn on my laptop the screen is black and it keeps saying DISK ERROR REPLACE DISK THEN PRESS ANY KEY. What should I do?
ps. Its also my first time owning a laptop
Comment by cunha, posted on Nov 07, 2007
hi i have IBM T22 and constantly freezes that i have to turn it off then turn it back on .
i have windows xp it runs good for 1 hour on ac power then it freezes or the screen goes black. this was 1 month ago!
now it loads windows stays on for 2 min and either freezes or the screen goes black .
i thought maybe its the windows so i did a clean fresh restore but it freezes when trying to install windows. i did install 2x256MB RAM 5 months ago
i sold my old ram 2x128MB on EBAY.could the problem be the ram.
i also installed the latest BIOS and i got a new battery and charges very good can you help me ?
Comment by Guest, posted on Nov 07, 2007
same issue
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For CMB Software T43 750 512/60 14...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 696
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
