Question about Brother MFC-8440 All-In-One Laser Printer
Scan from brother MFC 8440 to pc
Was able to scan pics to apple pc BUT  now brother does not see apple pc when trying to scan. The computer will print to brother fax/scanner>>>>
    Champion:
  • 320 Answers
You need to make sure that the brother printer is et as the default printer
Posted on Jan 14, 2009
UNABLE TO CONNECT TO MY PC
I am not sure this machine has an automatic Scan to PC option. Brother seems to like to avoid this part of most machines. Depending on your Operation System you will still be able to access the scanning system. The operation system would define which method it uses. Win XP you can access the scanner through the Printers and Faxes option on the start menu. Go to printers and faxes and then from there access scanners on the sidebar. Find your machine and open the inbuilt scanner software to scan your photos and save them to your computer. Then e-mail the saved files.
Aug 13, 2014 | Brother MFC 240C All-In-One InkJet Printer
Scan wont work on mac psc 1410v
First are you trying to scan using the scan button on the all-in-one or from the computer? If you are trying to use the scan buttons, you need to install the HP full-feature software package: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=458978#N193 . (If you need to expand the section marked drivers.) Uninstall the printer and disconnect the data cable before installing this full software.
If you installed the basic drivers that came with the Mac OS, you can scan using Apple Preview and Image Capture software. You can also acquire a scan from the Print & Fax > Printer browser. Open the software from the dock or from the Applications folder. In Apple Preview, choose File > Import from Scanner. In the Image Capture program select the all-in-one from the list of devices.
For the Print and Scan. Open System Preferences from the Apple Menu. Click Print & Fax and select the all-in-one. Click the Scan tab and Open Scanner. Then click Scan.
With the HP software you can launch a scan from the computer or from the scanner (but only if the monitoring program is running). You need to set up the HP Utility for the scan task manager.
This site has the full set of steps: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02456650&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=458978#N2158 .
Sometimes an all-in-one will work for printing but not for scanning due to a damaged cable. Scanning requires bi-directional communication with the printer. Try replacing the data cable. If you use a USB hub or print server, try a direct connection to the computer.
I hope this helps.
May 14, 2011 | HP PSC 1410 All-In-One InkJet Printer
Can I scan a document to PDF?
any scanner, indeed any document, picture format can be saved as pdf. i would suggest first scanning the document as text (for example to words, or openoffice or indeed whatever you use as your document management program) and then port it (sort of print operation) to any free available "translator" program which allow you to save file as pdf. alternatively you can scan your document as jpeg and then save it as pdf, but this tend to produce very messy outlook and results are usually horrible.
Jul 27, 2010 | Brother MFC 8440 All-In-One Laser Printer
I am a first time user of the scan function. Brother MFC 8440.
Hi there
I myself would just scan the one first and send it to your PC and then scan the other part and send it to your pc and then just copy the first 1 in to the Microsoft word program and then copy the second one and past it into first under it so it becomes as 1 then upload it to your email and send, this is what I do.
Or of cause you can upload 1 first to your email then upload the other one to your email and send.
All The Best Pineworks
Feb 18, 2010 | Brother MFC 8440 All-In-One Laser Printer
SCANNER does NOT respond.
You need to have scanning software installed as well, when you press scan a program should open on your computer to accept the scans. Check in control panel then scanners and faxes and see if the scanner is there.
Jul 20, 2009 | Brother Multi-Function Center MFC-240C...
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
How to scan on my mfc-235C
You should use Brother's Control Centre.
Dec 23, 2017 | Scan Computers Brother MFC Color Inkjet...
Brother MFC-8440 All-In-One Laser Printer Logo
224 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
