Question about Mitsubishi WS-65869 65" Rear Projection Television
I own a Mitsubishi WS65869 it has not been working for a few months now. All I remember is shutting off one day a green blinking light started and does not turn on anymore. Can you give me some idea to what is wrong and how it can be fixed, because I am tired of looking at my 26" tv. thank you
    Problem Solver:
  • 5 Answers
It did'nt cost me that much to fix at a repair shop and I'm very pleased!
Posted on Apr 22, 2009
    Problem Solver:
  • 14 Answers
Hey There,
It sounds like you either have a bad DM power board or a few caps (capacitor) are blown on your board. If you are comfortable with soldering then you will need to replace your Caps which are 1000uf 16V 105C and I would replace all of them ($1.25 ea). I found this great PDF online to help (this is not your model# but it expalins where and what your DM Power board is located) If not, Sears Parts carries DM Boards for your Mitsubishi - call in your Make/Model# and tell them you believe your DM power board has gone bad. The board should cost no more than $50-$70. Replace the board and let the TV blink for about 30-45 secs and it should turn on. If you decide to take it to an electronics shop, unless you know the owner, prepare to spend anywhere from $800-$1100..
Good Luck and Happy Holidays..
Posted on Dec 23, 2008
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
Mitsubishi WD-52525 with blinking green light problem
The #3 post worked for me. I first just did the capacitors and it did not work at first, but I got it reset. It worked for 2 months and lost power the other day in a storm and the blinking light came again and would not reset. I put in the switch and followed his directions and it work perfectly. Sweeet. The switch was easy. The capacitors were not hard, but very detail oriented. I work on copiers for a living, so I am used to taking things apart and back together. You must be able to solder and reassemble pretty well, or I would hire someone to do it.
Sep 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp worked for a few days and now it wont power up, now when you turn it on the light blinks green and then the yellow lamp light comes on and no sound or picture.
when the set shuts down check to see what the error code is, press the input and menu buttons at the same time, hold them down for 10 seconds, the green light should blink a two digit code, if this is 38 then you have a thermal sensor problem and need to call Mitsubishi for extended warranty repair.
Sep 08, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 03, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Help with green light blinking, HDTV integrated 1080
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 19, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
