Question about Konica Minolta PagePro 1350W Laser Printer
Know how to remove/access/clean transfer roller on Konica Minonta PagePro 1350W?
The last few days my printer output has increasingly bad dark lines on the edges of pages. According to the online manual for this printer the problem is that the transfer roller is dirty. The cartridge is brand new and perfect. The roller is not readily accessible via the toner door and the manual says to see a vendor/repair facility. The cartridges for this printer literally cost more than the printer itself, therefore I'm not thrilled about paying some overpriced geek for a service call. And I need my printer all day every day. Does anyone know how to access the transfer roller for cleaning? Thanks!
  • 1 more comment
  • Anonymous May 04, 2008
    Yes! I have the same problem and now, after a while I'm printing with that problem, the ink is dropping everywhere inside the printer... I have a 2400w... but it looks the same mechanic...
  • Anonymous Jul 23, 2008
    I have the same problem. The paper looks horrible.
  • DJNINPS Sep 26, 2008
    I have two lines through the center area of my paper, one solid the other somewhat broken. Thanks for any help with this problem.
  • 214 Answers
SOURCE: konica minolta pagepro 1350w error light won't stop flashing
pleas install status monitor, it will tell you what is wrong
Posted on Jul 02, 2008
SOURCE: just bought used konica minolta
Konica Minolta Link, select your operating system, and down load your 1350W pagepro driver
http://www.minolta-qms.com/support/current_printers/pp1350w_sup.htm#drivers
Cheers
Conrad
KM Dealer Cornwall
  • 3 Answers
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Posted on Apr 16, 2009
  • 55 Answers
SOURCE: Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Posted on Apr 25, 2009
SOURCE: Konica Minolta PagePro 1350W Laser Printer won't print anymore
You have to be sure that you are connecting the printer in exact the same USB port. If you are connecting to a different port and not to the one from was disconnected, the Windows is installing another copy of your printer. Check this, I believe this is the solution to your problem.
Posted on Aug 23, 2009
Printer feeds more than one sheet at a time
clean the rollers and replace the sep pad or sep roller which is the bottom roller, first one is pickup top one transfer bottom sep. or replace all
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 20, 2014 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
Stop streaks on printed copies pagepro 1350w
streaks are caused by toner on paper path rollers, clean these and it should stop. Also dont overfill the casettes with toneer ( common with refurbished)
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta page pro with windows 7
I looked at the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1350W
and you are correct -- there are drivers for 2000/XP, and for 95/98, but nothing for Vista nor Windows 7.
Find an old computer running Windows 2000 or XP, and connect the printer to it, and "share" the printer across your home-network.
Apr 07, 2010 | Konica Minolta PagePro 1350W Laser Printer
I have a Konica Minolta pagepro 1350W printer. I
Please diregard. Since I was using an aftermarket toner cartridge, I took a chance and bought an OEM cartridge and... voila... it's working fine. Apparently, all I had was a bad cartridge.
Oct 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
I have a konica minolta Pagepro 1350w and when i
if it occurs during printing you have a dirty charge wire in your drum unit, there should be a way for you as the user to clean, it may have a charge roller which you cannot clean. if it occurs during copying then your **** glass is dirty under your adf (1/2" strip of glass) clean with soap and water or glass cleaner (no ammonia)
Jun 21, 2009 | Office Equipment & Supplies
PagePro 1350W won't pick up paper
Clean the rubber roller that draws the paper in with isoproply alcohol, in future, blow dust off top sheet in paper stack before printing.
May 19, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica pagepro 1350W
There is no cleaning sequence for the 1350w. I usually just pull the toner unit out and clean the roller, etc. Compressed air for the moving parts and hard to reach places. Best to do it outside.
Sep 05, 2007 | Konica Minolta PagePro 1350W Laser Printer
HELP WITH INK LINES DOWN THE SIDE OF PRINTOUTS
If the line is solid from top to bottom of the page, the problem can be in different parts of the printer. Try a different toner cartridge if you have an extra one.
Jul 25, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
496 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
