Question about Toshiba MW27FP1 27" Flat TV/DVD/VCR Combo
Dvd shows perfect, but superimposes image when watching other channels.
I can watch my dvd ok, but when i selsect tv to watch a channel the dvd signal is superimpose on the screen.
SOURCE: Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Posted on Mar 09, 2008
  • 284 Answers
SOURCE: Toshiba D-VR650 can't tape says canot record protected image
Posted on Feb 10, 2009
SOURCE: I bought dvd hdd recorder
i have a targa 5500x from lidl cant copy from hard drive to dvd as i have done this many times but the dvd drawer keeps opening telling me to put in blank dvd and i keep doing this but getting no where,
Posted on Jun 28, 2009
SOURCE: Toshiba d-r400 recording
I don't see anywhere in the program menu to input a channel number to be recorded, only date and time.
Posted on Jan 25, 2010
  • 7 Answers
The short answer is "yes", but it really depends on your TV having more than one input.
You would put a cable splitter (see Google images) on the wire that comes out of the wall. One of the OUT connections would be to the cable box, and the other would go directly to your Toshiba unit.
Depending on the outputs of your cable box, and the inputs of your TV, each unit would be connected to a TV input either by cable or video connections. You would then switch back and forth between the input from the cable box - when you wanted to watch live, digital TV - or the Toshiba when you wanted to set up/watch recordings.
Posted on Mar 14, 2011
SOURCE: Our new Toshiba SDV398KC2 will not play a DVD. It
I've seen this behavior before.
For this model, I *think* that you need to use the component connections/input in order to view the DVDs. If VCR shows ok when using the cable, but not the DVD (and it seems to work since it goes up as if playing), try to connect the component (blue/green/red connectors) and it should work.
Don't forget to switch input on your TV to component.
P.S. If you have HDMI on both this dvd/vcr & your TV, it should work with that too.
Posted on Mar 22, 2011
0 characters
1 Points
Panasonic dmr xw385
Have you got the tv aerial connected into the dvd?
Oct 09, 2013 | Panasonic DVD & Blu-Ray Players
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | DVD & Blu-Ray Players
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can i record from tv to dvd
make sure the cables are connected correctly, the manual will show that.
If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
Feb 13, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Watching digital tv using a Panasonic DMR-EZ47VEB
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Watching tv while recording onto vhs or dvd
This could be a couple of problems. I'm not trying to make you feel dumb or anything but sometimes people miss the obvious. Do you have an universal remote? How is your vct wired to your tv? Does your cable go to your vct or your tv first? These sound like silly questions but they are important.
Jun 02, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Toshiba MW27FP1 27" Flat TV/DVD/VCR Combo Logo
16 people viewed this question
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
