Question about HP Photosmart C6180 All-In-One InkJet Printer
HP C6180 will not print with any megenta color
All new and original HP ink. So far I have cleaned everything...print heads, cartridges, metal things in printer and printed test page after test page with still no magenta. Status shows both lt. and dk. almost full.
  • Anonymous Apr 24, 2009
    same problem but will not print magenta or light magenta now.
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
Magenta & light magenta not printing photosmart c6180
The ink level in the color cartridge has three different colors in it. You may need a new cartridge. Magenta is usually the first to go out.
Dec 14, 2017 | HP LaserJet Office Equipment & Supplies
Black ink will not print but colors do
Most likely culprit is a dried up ink within the nozzles themselves. The best things for getting rid of dried ink in the nozzles is to use either a standard bathroom cleaner or rubbing alcohol. With the printer on open the door as if you were replacing ink. With the ink cartidges visable, unplug the printer so they stay put. Remove the cartridge and spray the cleaner in the where the ink is taking from the cartridge and clean it with whatever works. I really really good trick is if you have an old cartridge you can use a syringe to fill up the empty cartridge with your cleaning solution or rubbing alcohol. Insert the cartridge and run some test prints. This will for sure run the cleaner through the nozzle and hopefully dissolve the blockage.
Nov 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP C6180. I think the Black color print head is clogged. How to remove the print head for cleaning?
The print heads in the C6180 are not removable.
I would suggest getting an 02 XL black cartridge and an 02 Photo Value Pack (because it includes all colors plus photo paper for much less than the cost of the color cartridges separately ... and YES the are FULL 02 cartridges!) and run several head cleaning sessions from the setup menu.
It should do a deeper cleaning each successive time you run the same cleaning, so run 3 black head cleanings in a row (3 is the deepest).
Then disconnect the power from the unit, press and hold the # and the 6.
While holding the keys, reconnect the power to the unit until you see a reset message or until the unit turns itself back off.
If the unit turns itself back off, release the keys and press the power button.
The unit will gyrate and click and whir for quite some time and eventually settle in to a ready state.
At this point, you should be out some ink, but the unit should be printing again.
If it isn't, there really isn't anything you can do.
You can call HP at 1-800-HP-Invent and ask about their trade-in/trade up options for this model.
You can get really good deals on current model printers by trading in your defective unit !
Usually you will have a choice of about 3 replacement trade in (if the C6180 can be replaced with another C6180) / trade up (equal or better models) for your specific printer.
Jul 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Black ink cartridge wont print, have installed a new ink refill still no joy. Will print in all other colours.
Well if you already installed a new black ink cartridge and still wont print, then try cleaning your printer head. It can be that the some ink was hardened and got stuck preventing you to print a black color.
Jul 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Jan 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
403 people viewed this question
Ben Johnson
