Question about Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer
Keeps beeping i have a kenmore 3.5 and i dont understand why it keeps beeping. last night i had nothing in it and it was beeping. right now i have clothes in there and it's beeping. how can i get it to stop?
  • amyl323 Mar 23, 2009
    Kenmore super capacity 3.5 beeps intermittently for no appatern reason. I checked for loose connections wit no luck. Replaced plug and receptical thinking a loose power circuit. No change. Randomly begins beeping.
  • dibber005 Apr 07, 2009
    Times three... Same thing where it will beep and flash lights for no apparent reason. I also tried resetting the electrical equipment. Our washer is two years old, looks like we will be making an appointment with Sears Online... I can keep you posted!
  • Electrolux Master
  • 5,323 Answers
Stuck door switch or mis coommunicating control board
Posted on Mar 09, 2015
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
High oil warning ml350
chec the dipstic level in the engine--shed be in the safe zone-if above then its overfilled--dont want to driveit if its way above--will need to drain a quart
Nov 14, 2013 | Cars & Trucks
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
Kenmore electric dryer won't start
it is possible that your belt is broken open the door manually turn the drum by hand if it turns frely then the belt is broken if not it could be your door switch that has failes but normally for this problem its a broken belt
Mar 15, 2009 | Dryers
Ps3 problems
Make sure all disks are ejected first. Try holding down the power button on the front near where you put disks in. Keep it held down until it beeps a second time (5-10 seconds after the initial/first beep). Get updated to version 2.2 (came out last night). Good luck!!
Mar 21, 2008 | Sony Playstation 3 (PS3) Console
F10 error code
Need model number please. It should be behind drawer on left or right.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kinmore 44092 Washer - can't get it to start any cycle
Try some WD40 on the machine door mechanism, not on the door; & open/close the door while the machine switch is off.
Retry the machine with clothes.
Nov 20, 2007 | Kenmore Energy Star 44092 Front Load...
Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Jul 16, 2007 | Kenmore 67082 Electric Dryer
Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer Logo
540 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
