Question about LG WD-1280FHD Front Load Washer
Error code de
Hi load the machine then after a few seconds error code de displays with a canstant beeping.
  • 3 more comments
  • katieO103 Apr 26, 2008
    turn it on to start a load and DE comes flashing up. I have tried nothing.
  • Grandadh Apr 30, 2008
    My LG 1480FHD now shows dE code on start but starts after several minutes. dE code is for door not closed. any info on reboot prcedure mentione elswhere in LG faults or any relevent tech info. Thanks.
  • Anonymous Jul 06, 2008
    jes i have the same problem
  • Anonymous Mar 23, 2014
    Hauzen dE error code
    Error code de
    Champion:
  • 210 Answers
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Posted on Jun 04, 2008
    President:
  • 1,294 Answers
Refer to the users' manual re overload. The book usually covers everything
Posted on Apr 11, 2007
Top load machine, been fine til today, will not move thru cycle, keeps turning itself of with 'de' notice, also has leaked some from inside machine
Troubleshooting LG Top-Loading Washing MachineDoor Error. The washing machine gives a flashing beeping DE error that the door (top loader) is still open while this is not the case. The small magnet has broken/fallen off. Attach a new magnet to the door (top loader) that will trigger that the door is now closed. Why dE Error is displayed on the panel of the Washing Machine
Why 'dE' Error is displayed on the panel of the Washing Machine? Last Update date : 2017.01.19
You may encounter a situation when your washing machine displays 'dE' error. This error appears when the door is not porperly locked.
If the Machine is displaying "dE" error, kindly check for the following :
? First and foremost the door must be properly closed.
? You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact).
? Also, you can check the end of the drain hose is submerged in water.
Jan 02, 2018 | Washing Machines
Frigidaire affinity front load washer, my power went out and came back on, now the washer keeps beeping 3 beeps about every 30 seconds. Error code E91 will flash up when I push any button
Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Apr 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
Beeping flashing "H" and "F" wont wash
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
Error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Aug 21, 2008 | Washing Machines
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Error code de
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Mar 18, 2008 | LG WD-1280FHD Front Load Washer
LG WD-1280FHD Front Load Washer Logo
1,060 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
