Question about Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch free standing dishwasher (can't find the model #) that doesn't drain the used water when finished. Are there any diagrams that I can access to check how to remove and check the drain?
  • 42 Answers
Just remove the screen from inside you will see a torx screw to the left side of the sump remove it. pull the protective cover of the drain pump impeller. once removed you can see if anything is in the drain. if the impeller seems fine you eithe have a bad drain pump or something is in your drain between the dishwasher and the sink clogged.
Posted on Dec 20, 2008
Model SRV4 3MO. Water does not drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 06, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Have an dishwasher that i need to tilt back to get it finish the cycle.It gets to a certin point in the cycle then stops. i looked it up on the net and this has been a nice temporary solution but I need to...
go to appliancepros.com to find your model it sounds like the water pump is failing they have a 800 number where they can help you figure out whats wrong and what model it is for sure. hope this helps you.
Mar 23, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch Dishwasher
To find the model number I have to open the door and faintly etched into the metal surround at the top I can see the model number.
Aug 31, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Cleaning the drain of a bosch dishwasher
had the same problem if you remove t20 screw on the left side of the bottom bowl & remove plastic cover this is the drain pump & can block with food or glass particles clean it out & check it revolves & should be ok
Jun 16, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosh dishwasher Class1xx
I think if u take the left side pannel off u will find the meatering tank clogged up which can not fill up the machine at diffrent levels.
Jan 02, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
Aug 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
151 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
