Question about Panasonic CT-2788YD 27" TV
Old Panasonic TV
TV was working fine. Turned it on last night and it has oval color bands running through the screen. Kind of looks like an weird colored eyeball. The color on the rest of the set looks washed out.
    Genius:
  • 1,074 Answers
Take your set to a tech could be having problem in your video circuit or the neck board socket need to be replace.good luck.
Posted on Mar 30, 2007
I have an LG 50PS8000 plasma tv which is nearly 2 years old. For the last few months its has occassionally been getting a red haze over the entire screen which either dissapeared on its own or went if you...
I've also had a popping noise on our 50" LG plasma TV, however the picture has not gone, but has turned grainy and colors are weird. Can this also be a blown fuse or a more severe problem (ysus board or similar)?
Apr 08, 2011 | LG 42LC2D 42 in. LCD HDTV
Picture has double exposure as well as curved, color also is distorted with pink at the top of screen. It is on a good surge protector. It was fine last night and just started it this evening when we...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Samsung PCN5425R 54" Rear Projection...
KP-57HW40 rear projection TV colors out of alignment and warped
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Jan 04, 2010 | Sony KP-57HW40 57" Rear Projection...
TV Turns Off, Color is Turning Technicolor Blue-Green
sounds like the tube is going on the set best thing to do is consider buying a new tv or take to your local tv repair shop and they should be able to sort it for ya :D
Mar 10, 2009 | Daewoo DTQ-27U4SC 27" TV
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
CRT TV Screen Colors Off
The tv needs degaussing (demagnetizing) unplugg the set tonight and then plug it and turn it on in the morning. You should hear a a "bonk" noise when the set is first turned on after being cold- this is the internal degausse circuit working and it should fix your problem if you don't hear the "bonk" sound or it does not fix your problem call arepair shop to have the degausse your set and possibly fix the internal degausse circuit.
Dec 23, 2008 | Panasonic CT-32HX42 32" TV
Weird colors on my tv
If it is a tubed TV the spot suppressor is no longer working.
Mar 07, 2017 | Sharp Aquos LC-32D40U Television
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
chris
Aug 04, 2006 | Toshiba 36A40 36" TV
Panasonic CT-2788YD 27" TV Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
