Question about Nike WC0021 001 Mettle Hammer watch
Battery Replacement How do I replace the battery for WC0021?
  • 2,334 Answers
You have to dismantle your watch first.
Check the back of case- if there are visible screws- undo them and take caseback off. You should see the battery. Take it out, read the numbers on battery and replace with the same one.
If you can not find any screws on caseback- you have to undo screws from the dial side, get the movement out and then change the battery.
BE WARNED: if the watch must be opened from dial side, you can easily damage it as some particular skill is needed. Do it on your own risk.
Good luck
Posted on Dec 19, 2008
I have a Nike WC0021 watch and it beeps every hour. How can I turn it off?
Press and hold the top right button for 3 seconds then release - this should turn off the 'chime' function.
May 31, 2016 | Nike WC0021 001 Mettle Hammer watch
Where can I buy the strap of my Nike wc0021?
Check in Here I just bought a damaged part of my Nike Hammer that I've been looking for about years!!! Don't gave up your awesome watch!!! www.easycarts.net
Dec 30, 2012 | Nike WC0021 001 Mettle Hammer watch
I need a new watch strap for my Nike Hammer WC0021 sports watch. I have lost the pin (43mm in length) and the metal rectangular bar from the end of the strap (hence it cannot stay on my wrist) but I...
mcdevito75 here, Best bet, look for a small watch repair shop in your area, they should have replacement pins. Approx. $5.00 maybe even less John you can also type into serach, Contact Nike Hammer Watch.com Nike has to have a web site.
Feb 09, 2011 | Nike WC0021 001 Mettle Hammer watch
Change battery
if you watch a notch in the middle of the watch back then all you do is slip a large coin and twist off the capsule top by pushing down and turning counter clock wise. If the back of your Nike has a plate with 4 screws in the corner then y ou need a precision screw driver and unscrew all 4 screws on the back to access battery back.
Oct 17, 2010 | Nike WC0021 001 Mettle Hammer watch
Battery is gone (I think) and regular watch repair places don't fix it (need a special tool to open it)
does it have a slot on the back ? usually Nike watches are made to easily replace the battery usually with a nickle slot on the back or screws on the corners. The batteries they have are usually common 2806 or similar coin sized batteries. It will say on the back of the battery .
Most jewelry or watch repair shops can easily replace these batteries. if you bought the watch within a year , have receipt and something is broken. You can send it back to nike to be repair for free. It is done by parsec located here http://www.nikewatchrepair.com/.
Oct 14, 2010 | Nike WC0021 001 Mettle Hammer watch
How do you change the battery?
Thank you for contacting FIxYa.
I would read the NIKE support site before deciding to do any battery changes on your own. As a retail jeweler/watch service tech I would HIGHLY recommend you doing what they suggest:
http://www.nike.com/timing/
Best regards. Jewel
Sep 02, 2010 | Nike WC0021 001 Mettle Hammer watch
My strap has broken, can i buy a replacement?
mcdevito75 here, Yes you can, look for a small watch repair shop in your area to save on cost of installing the new band.
Jun 20, 2010 | Nike WC0021 001 Mettle Hammer watch
Battery replacement
If you have a warrantee with your watch you may have to return thew watch to the manufacturerer for battery replacement. Othet than that, most any jeweler can replace the battery. Mike D 75
Jun 07, 2010 | Philip Stein Teslar Stainless Steel Small...
I can't find a replacement battery, I have 2 3
Go to "http://relicbrand.com/pdf/Service_Form.pdf" and you will find an order form with prices for repairs and battery replacement.
It may seem expensive for a replacement battery but if you see the number of people who can't get their watches to go after battery replacement, you wouldn't hesitate to send them off.
Mar 17, 2010 | Relic 0504648FA
Sekonda 3850 battery replacement
Hi, its Richard, after battery replacement before replacing watch back, there is a small hole in the movement near the edge if you look down it there is a metal plate at the bottom gently press this with a fine screwdriver, the display will then come on, it is a reset switch, regards Richard.
Aug 20, 2008 | Watches
Nike WC0021 001 Mettle Hammer watch Logo
620 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Electro Med Services...
Are you a Nike Watch Expert? Answer questions, earn points and help others
