What does a watt risister do in electric heat circuit
Ruud model UBHA-17J14SFDA1 has a L80-10F watt rister. The customer wants to replace it. Is it necessary and can you still get one?
  • 8,220 Answers
That is a Temp limit. 80°F minus 10°F
Posted on Dec 19, 2008
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
My customer has a Rudd Model UBHA-14A00NFAA air handler. I have replaced the 24 volt transformer twice and am about to install a third one. Initially it was suggested to me that the transformer in the...
John from one service man to another, most of the time I have seen that many transformers fail is when there is bare wires touching somewhere from the outdoor unit to the air handler. This cause a small short in the circuit. Usually its when there is a crawl space under the house or even when the wiring is up in the attic. I have seen birds, squirrels, dogs and even rats chew thru thermostat wire. Hope this helps you . Have you thought about putting a small 5 amp fuse in series with "C" on the thermostat?
Jul 11, 2011 | Ruud Heating & Cooling
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
I have a Rudd A/C-Heat Pump, model UBHA-14J11NFAAI. My Air-Handler fan is inop, with it switched to A/C or Fan only. My thermo seems to be ok. proper low voltage on all of the wiring down to unit. Had to...
Hello,,there is a way to comfirm that but you will need a meter that reads microfarads, after discharging the capacitor with a insulated screwdriver you simply put you meter leads to each terminal on the capacitor with tje meter set to microfarads, if the capacitor is good it should read the same microfarad reading thats printed on the capacitor, if not replace the capacitor.
Apr 26, 2011 | Ruud UBHC Air Conditioner
Air handler motor stopped working
Check the capacitor before you replace the motor. It's a common problem that's easily fixed. Make sure the fan rotates freely.
May 23, 2010 | Ruud UBHC Air Conditioner
Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Mar 02, 2009 | Ruud UBHC Air Conditioner
Need to Replace Heat ELements
you remove the screws that hold on the base plate that has the sequencers mounted on it. pulling it out so the elements clear the sides of the unit. once you remove it you can easily see the heating element coils which you can purchase a restring kit fairly cheap at your local appliance parts store. just remember to stretch it out uniformally the same length as the old one, reinstall the heat kit the same way you removed it. kit comes with new ceramic gromets if some are damaged. these units do have a 5 yr warranty on the heat strips.
Jan 12, 2009 | Ruud UBHC Air Conditioner
Filter Placement Ruud UBHA
hey brad first you need to indentify wich is your supply and wich is the return after you have done that the filter is allways on your retun side however not allways is the filter set up at the air handler sometimes its in a duct sytemn on the ceeiling or wall hope you find it
Jul 05, 2008 | Ruud UBHC Air Conditioner
Ruud ubha
Does the fan on the outdoor condensing unit come on when the compressor does? If so, Is the condenser coil clean so that the airflow from the fan can remove heat from the condenser coil so the compressor won't overheat and trip the internal overload compressor protection circuit? If yes then is the indoor evaporator fan working properly? If yes are your filters clear and evaporator coil clear so that adequate air is flowing over the coil to prevent the compressor low pressure protection circuit from tripping? If so is the refrigerant charge on the system correct- either overcharged or undercharged can trip the compressor protection circuit. By now you should have come across an explanation for your compressor short cycling. If I had to guess I would bet on inadequate airflow over the condenser coil do to a faulty condenser fan motor either not turning at all or turning for a few minutes and then stopping when it overheats. This is likely caused by an unsealed replacment motor being used outdoors and water/rust has accumulated over the winter season and/or the capacitor is bad (in this case the motor may be turning slowly backwards) or just plain old worn out. I hope this helps get you to cold air sometime soon GL!
Jun 06, 2008 | Ruud UBHC Air Conditioner
Cannot reach the temperature setpoint in heating sequence
I think what you are trying to ask is should you use a 2 stage thermostat or stick with a single and just double the stages on a relay to work at the same time. As long as the relay can handle the amp load, there is no real need for a 2 stage heat system, unless you are concerned by the efficiency of $$. If I am missing the question please reply.
Dec 11, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
