Question about Sony Playstation 3 (PS3) Console
PLAYSTATION 3 WIRELESS NETWORK
My playstation 3 will not detect my netgear dg834g router modem wirelessly have done settings the light on the modem with wireless signal is on but ps3 not detecting it help please thanks mark
  • strawman Feb 21, 2008
    I have added the Playstation to the list of allowed MAC addresses and still it fails to connect. The PS3 fails to obtain an IP address. But strage to say the PSP manages.
    Any ideas?
  • salsapapi200 Jul 17, 2008
    hi
    im having problem with my wireless network on my ps3 it wont let me play the games on line.
Where can i find the filters tab on the router
Posted on Aug 20, 2008
You may need to add the PS3 MAC address to the router's list of allowable MAC addresses:
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the router. This is usually done by typing the router's IP address on your browser. ie http://192.168.0.1
3. Locate a tab for FILTERS or similar
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
Posted on Dec 02, 2007
Get a firmware update for ur router
Posted on Apr 08, 2007
Netgear DG834G wireless router wth built-in modem doesn't connect
Check if you have types all the configurations properly, namely Encapsulation / user name n password.
Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
Hi, I have a netgear DG834G version 3 wireless router. I want to buy a wireless printer, will this router support one? If so, have you any opinions on the best buy? Thanks
any wireless printer should and will work with this modem-router as long as it's wireless settings are configured right, if you already have a computer connecting to this router wirelessly then that means the wireless functionality of your router is working. you just have to know the wireless settings of your router such as the SSID or the wireless network name, the type of wireless security and the wireless security key or encryption key.. once you have a wireless computer and it wireless feature is enabled it will automatically detect all networks name or SSIDs around the area, that includes your modem-router's and neighbors'.. when you try to connect to the SSID of your modem-router you will be asked for an encryption key or a password to be able to connect.. that will only happen if you have enabled a wireless security on your modem-router.
Jan 30, 2010 | NetGear DG834G 802.11G Wireless ADSL...
Need network security key or passphrase for my netgear DG834Gv4/DG834GBv4 !!! PLEASE( IP 192.168.0.1)
LOGIN
There is a login key for the router that can be accessed by opening the
address http://192.168.0.1 as described: after the login all settings inside the router can be changed.
Note: use a wired connection when going into the routers' ip address.
When you can not login with the default password, reset the device:
Restoring the Default Configuration and Password
This section explains how to restore the factory default configuration settings, changing the
router’s administration password to password and the IP address to 192.168.0.1. You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function of the Web Configuration Manager.
• Press the WPS button and Wireless button on the side of the router simultaneously. You can
use this method for cases when the administration password or IP address is not known.
Resetting to Factory Default Settings
You can use this method for cases when the administration password or IP address is not known.
To restore the factory default configuration settings:
1. Press and hold the WPS button and the Wireless button on the side of the router until the Test
LED turns on (about 10 seconds).
2. Release the buttons and wait for the router to reboot.
WIRELESS SECURITY + PASSPHRASE
The wireless security is a network name for wireless connection called
SSID: the identification name of your router.
The passphrase is used for a secure password getting permission to have wireless data transfer from the router to the computer and vice versa. ( No internet connection so far: only Local Area Network [LAN] )
MODEM
Because the device is a router / ADSL modem you'r able to setup the
modem part for connection on a telephone line to the internet / Wide Area Network [WAN] .
You should use passwords from the Internet Service Provider [ ISP ] enter and save them in the modem section of the device.
Support for DG834G on the internet:
http://www.netgear.com/Products/RoutersandGateways/WirelessGRouters/DG834G.aspx
Sep 22, 2009 | NetGear DG834G Router
WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
Mar 21, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Ps3
In order to connect ur ps3 wirelessly u have to open netgear settings by opening internet explorer and typing in this address 192.168.0.1 and then it will ask u for username and password that are admin and password respectively. After that i t will open up netgear settings on that click wireless settings on the left and on the right u will find wireless settings  first option will be name put any any name of ur wish then region select urs then channel select 11 mode g&b next under wireless access point check first two options then under security options select third one wpa-psk wifi protected and under that type ur network key or password in more than 8 characters and then hit applu. ur router is set on wireless network. now in order to setup ur ps3 goto this following link and find the screenshots to config ur playstation http://uk.playstation.com/help-support/manuals/
May 23, 2008 | NetGear DG834G Router
My netgear modem router DG834G
hello!
-- do you have other wireless computer on the network?
-- what is the model number of the wireless adapter that you are using?
-- have you check if the wireless settings on your router are still configured correctly?
-- can you get online if you are directly connected to the router?
Apr 07, 2008 | 3Com SuperStack 3 RAS 1500 Base Unit...
Setting up netgear dg834gmodem router
u will need to call netgear get your isp or ther dns server codes they will tell u it and u will enetr in the network adpoters properties area ok thx nick
Mar 13, 2008 | NetGear DG834G Router
Network key
Presuming your are meaning a WEP key (asked as network key in windows), you would find it by entering into your Modem's setup screen, selecting Wireless Settings, Wireless Security, and your key should be listed there
Hope this helps!
-Backu
Jan 14, 2008 | NetGear DG834G Router
Sony Playstation 3 (PS3) Console Logo
5,748 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
