Question about Microsoft LifeCam VX-1000 Webcam
Other person can't hear me
I just hooked everything up and when I check the vloume on my end I get sound and I can record just fine but when I accepted a video call they can't hear me they can see me.
  • Anonymous Jan 02, 2009
    hi, I have the exact same problem - - sound is fine for me (IE: I can do sound recordings, videos, etc), but on a video call they can't hear me. How do I fix this?
  • Jyackle5
    Jyackle5 May 11, 2010
    Did they turn on there volume to hear you
    President:
  • 8,637 Answers
Send them this info so the can check their audio & Video settings.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 12, 2009
When making outgoing calls I can hear the person on the other end but they are unble to hear me. I have a Nokia 6120 Classic.
first if your phone have a voice recording option check that your **** is working properly or not by recording any voice for 5 to 7 secs. If it is probable that mic is working properly say you listen the recorded voice than you might have muted the voce increae it by side bottons if present or from phone's sound settings
Jan 12, 2011 | Cell Phones
Caller can't hear me
if everything works fine check your audio setings lower right side of your screen right click on the speaker icon check playback devices and recording devices select using the drop down on the menus if there are other audio devices on the list try selecting that and play around your Mic if you can do a recording on microsoft and check if the mic is in mute undet the sudio properties under sounds check th mic settings ..... ^_^
Jun 05, 2010 | Plantronics PL-CS55 Wireless Headset
I installed my Mini Webcam Pro HO98756 without any problem. The person I talked to saw and heard me fine, but the person could only seem me but not hear me. What may be the problem? What can I Do? Thank...
Assuming you are running Windows XP or Vista, check the sound recording settings.
In the Control Panel, select Sound and then check if the webcam is selected as the source for the sound recording. Also make sure the sound recording volume level is not set to zero (which it often is!).
If your webcam driver is properly installed and has a microphone, this should fix it.
Jules
Jun 03, 2009 | GE MiniCam Pro HO98756 Webcam
Nokia 1208 - I can't hear what folk are saying
ur speaker phone is not working fine try to replace it or check it with your voice recording so it will confirm that u need to replace it or not
Mar 04, 2009 | Nokia 1208 Cellular Phone
Mic volume really low on Samsung Blackjack II
baby slobber is a dangerous thing... turns out the phone just needed time to dry internally. It took a while, but everything's fine now.
Jan 06, 2009 | Samsung BlackJack II Smartphone
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
In Call Mic Problem
hi there...
it seems there is some problem wiht the software....
hard rest your pda usnig camara+recording button+power button and reset it with stylus....but you will loose your data stored on phone.....bet data on storage card will be saved........
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 23, 2008 | Orange SPV M1000
Compaq C733TU
I know this sounds silly, but is your microphone plugged in?? Is it muted? Can you record anything using your microphone and Sound Recorder (Start, Programs, Accessories, Entertainment, Sound Recorder)?
Jan 30, 2008 | Broadcom BCM94306MP - IEEE 802.11b/g...
Logitech mircrophone
It may be that this person is "messing around" with you, or their speakers are rigged, from my experince, it sounds like your headset is perfectly fine, or your headset microphone switch was toggled on "Off" Msn is just a instant messaging chat, shouldn't have anything to do with your headset.
Nov 29, 2007 | Logitech QuickCam Express Web Camera
Microsoft LifeCam VX-1000 Webcam Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
