Question about Intel CASE 350W PWRS ALLIED W/ 24PIN + BALL BEARING, LISTED, BLK/ SLV COLOR 2 FRNT USB MICRO ATX (TM16324)
Monitor 2400 heater will shut down when I run My generator
We had a power outage the other day, 4 days total . And when I hooked up my new Homelite 5700 watt generator my monitor 2400 heater it would shut down when it went to go into high. It would do its regular start up and the shut down like it had lost power. It runs fine on a smaller 2400 watt generator I had borrowed or when it is on the regular house current. I was told I need a line conditioner with "pure sine wave". But they are very expensive on the ones I have looked at. Does anyone know if it has to be a pure sine wave or would a modified sine wave UPS/ line condition work. Or anything else I could try.
  • cruisn69 Dec 20, 2008
    Just to let you know I went to Wal Mart and purchased a RCA low profile flat power conditioner for $11.88. The best thing it worked. I ran My Monitor Heater for over 30 minutes on my generator with no problems
  • Anonymous Mar 30, 2014
    Have tried shutting off.
    Master:
  • 461 Answers
A UPS unit might work. Electronics need steady clean power.
Posted on Dec 19, 2008
Homelite genorator 2400 watts loud cluncking noise while running does not hold volts up long not generathing power
try runnig it not hooked up to anything if runs OK gen is to small for your application
Jan 01, 2014 | Electrical Supplies
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
WE HAD A POWER OUTAGE AND NOW MY MONITOR HEATER 2400 IT JUST HAS LINES GOING ACROSS IT WE CANT SET THE TEMPERATURE THEN WHEN IT FIRES UP IT LASTS LIKE 20 SECONDS THEN SHUTS DOWN, WHEN IT DOES THAT IT SHOWS...
Since you had a power outage, you possibly have a circuit board issue. Try unplugging the heater for a couple of minutes then plugging it back in. If that doesn't help then a new circuit board may be needed. There are 2 different circuit boards. One main circuit board and one for the display. I hate to inform you of this but this are both very expensive. The main board will cost somewhere around $400. I'm not sure of the cost of the display board. If you have someone replace them, have them do to one and see if it fixes it. If it doesn't, put the old one back and replace the other, that way you can narrow it down to 1 or the other. There is a place in Ashville, NC that will repair monitor circuit boards. http://www.mathiselectronics.com/product-services/Monitor-heater.html Go to this link and it will give you prices for the repairs. They guarantee their work for 3 years. If you contact them mention you heard about them from Niten's Heater Service. Sorry I can't be more helpful.
Dec 01, 2010 | Heating & Cooling
Just up graded from a homelite 4400 to a craftsman 5600 generator 5600 does not have enough output as did the 4400 why
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Oct 03, 2010 | Craftsman Electrical Supplies
My monitor 2400 suddently goes into error 13, I shut the monitor off for a few minutes and then it starts again, it has gone into error for the paste 4 days about 2 tims per day can you give me some idea...
It could be a dirty fuel filter or the small strainer located inside of the heater that is restricting the fuel flow. The problem could also be with the flame rod being dirty or touching the burner ring.
Feb 21, 2010 | Heating & Cooling
What is the proper proceidure to set exercise timer on a briggs generator model # 01938 and what year was this model manufactured? thank you
http://www.homegeneratorsystems.com/service_support/manuals/index.cfm?rd=1
This link will take you to their site where you can download their manual.
Setting Exercise Timer
The Home Standby Generator is equipped with an exercise
timer that will start and exercise the system once every
seven days. During this exercise period, the unit runs for
approximately 20 minutes and then shuts down. Electrical
load transfer DOES NOT occur during the exercise cycle
(unless an utility power outage occurs).
A switch on the control panel is labeled “Set Exercise”
(depicted on page 10).The specific day and the specific time
of day this switch is pressed is programmed into the
control board memory.This date and time is then used to
automatically initiate the system exercise cycle.
To perform the Set Exercise procedure:
1. Choose the day and time you want your Home
Standby Generator to exercise.
2. On that day and time, set the AUTO/OFF/MANUAL
switch to OFF.
3. Press and hold down the “Set Exercise” switch for two
seconds.
4. Set the AUTO/OFF/MANUAL switch to AUTO.“Set
Exercise” is complete.
For example, if you press the “Set Exercise” switch on
Sunday morning at 10:00 AM, the unit will run an exercise
cycle the following Sunday at 10:00 AM (+/- 1/2 hour).
NOTE: “Set Exercise” will only work if the unit is in the
Automatic mode and this exact procedure is followed.The
exerciser does not need to be re-set if the 15 Amp fuse is
removed or changed.The exerciser will need to be re-set if
the 12 Volt DC battery is disconnected.
If you want to change the day and time the unit exercises,
simply perform the “Set Exercise” procedure at the exact
weekday and time you want it to take place.
• To prevent possible injury that might be caused by such sudden
starts, always set the AUTO/OFF/MANUAL switch to OFF.
• Remove the 15 Amp fuse before working on or around the
generator or transfer switch.
Nov 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Blinking monitor screen
this might be overly technical, but it sounds like the video card is on the blink (no pun intended). I'd power down the machine, open it up, pull the video card, re-seat it, and power the computer back on.
If it continues to do this, that card is probably toast.
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
636 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
