Question about Sony VAIO VGN-S460 Notebook
My sony vaio s460 does not detect the hardrive, after I installed new 120 gig sata, I called to sony and they said tha I need the same hardrive 80m gig 5400 rpm, as the laptop comes from factory, it is true or it has another problem? I will apreaciate your help.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Sony Expert
  • 159 Answers
Customer care helpline NUMBER +1-^833_^272-^O777,,,,,,,CALL THEM
I'm not sure how big the drive can go up to on your laptop but I do know that you will need sata drivers for the harddrive to be recognised.
Posted on Nov 30, 2018
  • 903 Answers
I'm not sure how big the drive can go up to on your laptop but I do know that you will need sata drivers for the harddrive to be recognised. (if using XP) If you have not got the drivers for the harddrive then try googling for them and follow the instructions that comes with them. If you are using vista then the harddrive should be picked up. If you are still having problems visit this forum http://www.digitaldiver.net/yabbse/index.php?board=5;action=display;threadid=23370
for some more tips
I hope this helps
I hope this helps
Posted on Dec 19, 2008
  • 916 Answers
It may be that your machine can not handle a drive of that size. When I replace hard drives I always try to replace them with the size they came with just in case they do not support a larger size.
How to Boot Sony Vaio VGN-S460 Laptop without CD/DVD ROM and With bootable USB
If the BIOS does not have the USB as one of the boot options then you cannot boot up with an USB memory stick.
In this case you need to replace the CD/DVD drive with a new one.
Jan 17, 2013 | Sony VAIO CS VGN-CS220J/T Notebook
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Hello, i have sony vaio VPCEB46FG laptop & i have windows 7 64bit operating system & i want to install windows XP 32 bit but im getting following error "a problem has been detected and...
It is required to install the hard disk SATA drivers in the computer first. Download and extract the SATA drivers in a floppy drive, hard drive or CD on a different computer. Then, retsrt the computer by having the Windows XP disc inserted and beging the setup. During the setup process press the F6 key and enter>enter and then install the SATA drivers. Then, continue with the further setup process.
http://www.sony.co.in/support/product/VPCEB46FG
Select Windows XP Operating System and install the SATA drivers. Once, the SATA drivers are successfully installed you can continue with the further setup process with out errors.
You can also view a complete set of instructions on downgrading to the Windows XP Operating System and installing the SATA drivers.
http://esupport.sony.com/US/perl/support-info.pl?info_id=337#
May 31, 2011 | Sony VAIO VGN-S460 Notebook
Sony vaio VGN-s460 when I power up, the vaio screen pops up , then nothing. Any help appreciated
if you recently installed a software or a component, that caused the issue. if removing it or a system restore while on safe mode did not work, please consult the link below for some laptop DIYs
laptoprepair101.com
Sep 13, 2009 | Sony VAIO VGN-S460 Notebook
Have vaio VGN-S460, window 7. Can't get internet
Windows 7 is still a beta and Sony probably doesn't make drivers yet for the network adapter on that computer. You might be able to install the windows vista or xp drivers and that may work. You might have to manually install these drivers, however.
Jul 09, 2009 | Sony VAIO VGN-S460 Notebook
Fn key for laptop sony vaio vgn-s460p
the function keys doesnt need any extra driver.
but if you want to use tha additional features of function key like save, load, close and many more then you can get the software directly from official website of sony. alternativel you can download hotkeycontrol xp by which you can reconfigure you keyboard to add extra feature and options
Jul 06, 2009 | Sony VAIO VGN-S460 Notebook
My sony vaio does not detect the hardrive, and I installed new, and I called to sony and they said tha I need the same as it comes from factory, is it true or it has a motherboard problems?........I will...
Normally that is false and company's like to have only there parts in these machines as a way to ensure quality.
You could try and see if you can detect it in computer management in the administrative tools in the control panel if the drive is a slave or external.
If you are replacing or adding a new master drive make sure it is detected in the machines BIOS if not I would think the motherboard does not support a drive of that size or may only support certain types.
Dec 18, 2008 | Sony VAIO VGN-S460 Notebook
Vaio VGN-S460 won't boot
Maybe simply buy another SATA HDD to replaced faulty one, which you said it came with "clicking noises".
you also can try hold tee 'C" or "F12" when you power on the laptop to get from DVD booting.
Nov 27, 2008 | Sony VAIO VGN-S460 Notebook
Sony Vaio-s460
probably arent fully seating the ram modules. push them into the slot until the little side levers close on their own.
May 17, 2008 | Sony VAIO VGN-S460 Notebook
VAIO VGN-S460
check adapter output also may be problem with dc socket on laptop loose or somthing.
Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO VGN-S460 Notebook Logo
98 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
