The water tank located inside the door of the fridge is leaking into the bottom of the fridge under the deli door and freezing. We had this same tank problem back in August of '06 and LG replaced it now 8 months later it has happened again and they offer no help since the warranty expired in Oct of '07. Not sure why it keeps happening or where I can order a new part. Thanks
Peah, I had a couple of these tanks leak. I think they had an issue with this. The last one I had they had a kit where the substitued coiled tubing with 2 john guest fittings to replace the tank. This solved the problem. The part number I have for the tank is 4838jj1003a, you can get it at http://www3.sears.com/ for 17.95. I don't know if they will send you the tank or kit. You can inquire. Catriver...post back.
I was told the new part number to fix the problem is 4839JJ2003A I dont know if its a tank or tubes. I only know its going to cost me $49.99 at Sears in Candada.
we installed a new filter and now the water in the door does not work but it runs under the fridge
water dispenser keeps freezing Have had the main temp comp replaced about a year ago now problem is reoccurring again
Water not getting all the way to the door
